Solve Motion Position Homework: Answer at 6 sec - 10/46 m
  • Thread starter Thread starter missashley
    Motion Position
The homework problem involves calculating the position of an object at 6 seconds, starting from an initial position of 10 m, with a known position of 17 m at 2 seconds. The equation for displacement is provided, but there is uncertainty regarding the final velocity to use in the calculations. The discussion emphasizes that the problem may not involve constant acceleration, suggesting a more complex relationship between velocity and displacement. A hint is given to recall calculus concepts related to motion. The key takeaway is that understanding the relationship between velocity and displacement is crucial for solving the problem accurately.
missashley
Consider the plot below describing motion along a straight line with an initial position of x = 10 m.
http://img261.imageshack.us/my.php?image=asdfdp5.jpg
What is the position at 6 seconds? Answer in m.
The position at 2 seconds is 17 m.
delta d = 1/2a delta t^2 + Vi delta t
I didn't know whether to use 4 or 0 as the final velocity.
delta d = 10 or 46
The problem is much simpler than it looks. Remember from calculus how velocity and displacement are related.
Hint: Remember that this may not necessarily be a constant acceleration problem.
Bryan
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
