Motor Selection to Operate Golf Cart Steering Wheel
This discussion focuses on selecting a motor for operating the steering wheel of a golf cart, specifically requiring a 12VDC motor. The user estimates the golf cart's weight at 500 lbs, evenly distributed across the tires, and seeks to determine the necessary torque for steering at low speeds. Recommendations include using a torque wrench to measure the input torque directly on the steering wheel nut and considering a stepper motor with an encoder or a servo motor for precise control and feedback.
  • Understanding of torque measurement techniques
  • Familiarity with 12VDC motor specifications
  • Knowledge of stepper motors and servo motors
  • Basic mechanical engineering principles related to steering systems
  • Research how to measure torque using a torque wrench
  • Explore specifications and applications of 12VDC motors
  • Learn about the integration of stepper motors with encoders
  • Investigate the use of sprockets and chains for mechanical drive systems
This discussion is beneficial for hobbyists and engineers involved in electric vehicle design, particularly those focused on steering mechanisms and motor selection for low-speed applications.
jake2
Hi all,
I am trying to select a motor for a project that will have enough torque to operate the steering wheel of a golf cart. I'm trying to avoid over design as I want to be as economical as possible. The problem that I am having lies in determining the torque that is required to move the steering wheel. The golf cart will be operated on pavement at low speeds.
I am assuming the golf cart weighs 500lb that is evenly distributed to each tire. A requirement is that the motor be 12VDC.
I found an article (http://www2.ee.ic.ac.uk/cap/publications/2003/parking_torques.pdf) that outlines the torque needed to move the steering wheel of a vehicle at low speeds, but I am not sure that I can apply the findings directly to my situation.
If anybody can make any motor recommendations, or recommend a way to measure the torque I need, that would be great.
Seems the best way to find out what torque is needed would be to measure it. Do you have an idea of how to do this?
Put a torque wrench on the nut that holds the steering wheel on the column and measure the input torque. As far as the motor to turn the wheel, I would think about using a couple of sprockets and a chain to drive it from a stepper with an encoder or a servo motor so you can get some positional control as well as feedback if needed.
Sounds fun!
  • · Replies 19 ·
9K
  • · Replies 16 ·
