Mountain Climbing: Solving Uneven Tensions in Rope
  • Thread starter Thread starter kittymaniac84
To solve for the tensions in the rope while the climber rests between two cliffs, the vertical components of the tensions must equal the climber's weight of 596 N. The left tension makes a 65-degree angle, while the right tension makes an 80-degree angle with the horizontal. By resolving the tension vectors into their horizontal and vertical components, the equations can be set up to find the individual tensions. The horizontal components of both tensions must be equal, while the sum of the vertical components must match the climber's weight. This approach allows for calculating the tensions on both sides of the rope accurately.
kittymaniac84
A mountain climber, in the process of crossing between two cliffs by a rope, pauses to rest. She weighs 596 N. As the drawing shows, she is closer to the left cliff than to the right cliff, with the result that the tensions in the left and right sides of the rope are not the same. Find the tensions in the rope (a) to the left and (b) to the right of the mountain cliff
The shape of thislooks like a "Y" but with uneven tension. the left tention is 65degrees and the right tension is 80degrees.
how can i solve for the 2 tensions?
resolve the two tension vectors into horizontal and vertical components. The sum of the two vertical tension force components must equal the climbers weight force. The horizontal components must be equal to one another.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
