robera1
- 22
Consider the original double slit pattern from problem 1. Suppose that a third slit with the same width were added halfway between the original two slits. So that d goes from being 1 to being 0.5 for both.
Would point Z be a principal maximum, minimum, or neither?
I don't need any questions, I just need to know what happens to the pattern once a slit is added in between the two. I know that the minimums will change, so that there is a brighter spot in the middle of each line, and I think that the width of each will double (since you are halving the distance between them)
But I am not sure?
