Multivariable Calculus: Max/min values inside closed interval?
MSG100
Hi!
My question is:
Find maximum and minimum values of the function:
f(x,y) = 2x-y+x^2+y^2
when x^2+y^2 ≤ 4
I would like to solve this without using Lagrange method.
I get
x=-1 and y=1/2 when using partial derivative and set it equql to 0.
I can see that the maximum value must be at the edge of the circle, therefore x^2+y^2 = 4
f(x,y) = 2x-y+x^2+y^2 =
2x-y+4 =
2x - sqrt( 4 - x^2 ) + 4
I derivative and get:
2 + x/(sqrt(4-x^2))=0
x=-4/sqrt(5)
Hmm, is this really the right method?
MSG100 said:
Hi!
My question is:
when x^2+y^2 ≤ 4
I get
2x-y+4 =
You mean ##2x \color{red}{\pm} \sqrt{4-x^2}+4##. You get two ##y## values for each ##x## on the circle.
x=-4/sqrt(5)
I didn't check your last steps but, yes, that method should work. Don't let the square roots scare you.
Likes 1 person
MSG100 said:
Hi!
My question is:
when x^2+y^2 ≤ 4
I get x=-1 and y=1/2 when using partial derivative and set it equql to 0.
So (-1, 1/2) is one candidate.
f(x,y) = 2x-y+x^2+y^2 = 2x-y+4 = 2x - sqrt( 4 - x^2 ) + 4
I [STRIKE]derivative[/STRIKE] differentiate and get:
x=-4/sqrt(5)
Your work is fine, but when you solve for y in terms of x, you get two roots ##y=\pm\sqrt{4-x^2}##. You need to consider the second solution still.
Likes 1 person
Thanks both of you!
I forgotten the second root.
Now I can continue and see what I get for answer.
It wasn't as easy as I thought.
I get x=4/(sqrt(5) and x=-4/sqrt(5)
It seems that x=4/(sqrt(5) is correct when I studie the the 3D picture http://www.wolframalpha.com/input/?i=f%28x%2Cy%29%3D2x-y%2Bx^2%2By^2
Do I need to studie the egde of the circle using 2csot, 2sint? I increase the value by increase x.
Ok let's see if I'm on the right track.
I solve for y:
x^2+y^2=4
y=±sqrt(4-y^2)
I put it in the equation and differentiate:
f(y)=2*±sqrt(4-y^2)-y+4=
f´(y)=±(2 y)/sqrt(4-y^2)-1
When I set it equal to 0:
y= -(2/sqrt(5))
y= (2/sqrt(5))If I sum it up I have three candidates:
Point I (-1, 1/2)
Point II (4/sqrt(5)), (-2/sqrt(5))
Point III (-4/sqrt(5)), (2/sqrt(5))If I insert each point into the original equation I get:
Point I = -5/4 =-1.25
Point II = 2(2+sqrt(5)) ≈ 8.47
Point III = 4-2*sqrt(5) ≈-0.47
Point I = minimum
Point II = maximum
Is this solution good enough?
Looks good.
Likes 1 person
