Mulyiplying the effect on the load in a rope system?
  • Thread starter Thread starter Desmond108
    Load Rope System
The discussion revolves around achieving a "multiplication" effect in a rope system, where a 2-inch movement on one side results in a 4-inch movement on the load side. The current setup will only reverse the force, requiring more pull than the load's weight. To achieve the desired mechanical advantage, a compound pulley system is necessary, as traditional setups typically reduce movement efficiency. Suggestions include utilizing additional pulleys for faster load lifting and referencing crane lifting arrangements. The user expresses gratitude for the assistance received and indicates a future interest in further discussions related to physics.
Desmond108
Alright, so this is a crude drawing of my current system set-up:
http://img233.imageshack.us/img233/3570/loadtx3.png
So what I want is a "multiplication" effect, like a 2 inch movement on the "A" side will cause a 4 inch movement on the load side.
So what should I put in the red circle to get this effect?
Welcome to PF, Desmond.
The setup as shown will simply give you a reversal of force. That is, you will need to pull down on the user end of the rope with a force in excess of the load's weight. It doesn't matter what sort of wheel you put at the top.
To gain (or in your case lose) mechanical advantage, you need a compound pulley system.
Note that pulley systems are usually applied for the opposite of your goal. Pulling the rope 1 foot will result in a 6 inch movement of the load, but requires only half of the force.
Your goal is usually achieved by other means.
This sounds like homework.
Desmond, have a think about how you could use another pulley to lift the load more quickly than you're pulling. If not; have a look at some simple lifting arrangements on cranes.
Thanks a lot guys, I just looked at some diagrams of compound pulley systems and now I have what I need (well, I still got to put the system in a braced position).
You guys have been really helpful, I'm glad I joined PF.
My physics course at school in going to start soon so I'll probably be here more often then.
No problem.
Danger - you need to clear out your PM box.
brewnog said:
No problem.
Tell me about it. :rolleyes:
The problem is that I keep all of my PM's, because they're important to me. I used to clean out the box by saving them to HD. Then W killed my computer a couple of months ago, so I have to use either this one at work or hers at home. Either way, I don't have a place to stash them. I'm thinking to relocate one of my desktop or tower Mac's to a room with an electrical outlet and drop my stuff in there.
Unfortunately, my e-mail account is similarly plagued, so you can't even get hold of me that way. I'll gladly PM you my phone #, but there might be a problem with the time zones. It's a cell, so I have it on all of the time, but I might not be awake.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
