Can a Vertical Jet Engine Replace Helicopter Blades for Hovering Crafts?
  • Thread starter Thread starter Hornbein
    Helicopter Idea
The discussion centers on the feasibility of a hovering craft powered by a vertical jet engine instead of traditional helicopter blades. Key concerns include the stability and control challenges posed by a jet engine's thrust vectoring and the significant power requirements needed to counteract descent. Comparisons are made to existing technologies like the Harrier jet and electric vertical takeoff and landing (eVTOL) aircraft, highlighting advancements in battery power and design. The conversation also touches on the potential for future developments in this area, emphasizing the importance of proof of concept and regulatory oversight. Overall, while the concept is seen as promising, it remains in the early stages of development with many technical hurdles to overcome.
Hornbein
Summary: Have a hovering craft powered by a jet engine.
Instead of helicopter blades have a vertical jet engine embedded in the craft. Steer via thrust vectoring.
The angular momentum of the jet engine might not provide enough stability but surely there is some way to get that.
A simple jet engine pointing down requires a lot more power than the blades do. The way to understand this is to see how each would fall with no power. Each design requires only the amount of power to counteract the descent at the "zero power" speed. With a jet engine and no power, the helicopter would fall like a stone. It takes a lot of power to counteract that. A regular helicopter would fall a lot slower because the blades slow it like a (bad) parachute (see autorotation). It takes a lot less power to counteract that.
Another problem is that the aircraft would be harder to control. The act of keeping upright with a jet engine pointing down requires very fast vectoring. Modern controls can do that, but it makes the stability of the aircraft completely dependent on the control system. Helicopter blades can be above the vehicle, which is stable. The blades pull it up and keep it upright. A jet engine can not be above the vehicle because of the hot exhaust and the disturbed airflow. With the jet engine below, the vehicle is balanced on top of the jet thrust and is unstable.
EDIT: The crossed-out part is the "Pendulum Rocket Fallacy". It is not true. Thanks, @hutchphd .
Likes hutchphd, russ_watters and Lnewqban
Likes FactChecker
Once you put that much power in a "helicopter", it is a shame to not add some wings and get a much faster vehicle. Examples are the Harrier jet and the F-35B.
CORRECTION: The F-35B also uses a large jet-driven internal fan for its takeoffs and landings. It is STOVL (Short TakeOff Vertical Landing). I think it may have some limited vertical takeoff capability if it is light enough.
Likes Klystron, russ_watters, anorlunda and 2 others
Or you can look at batteries and electric power. These people are getting over 250 mile range, vertical takeoff, and vertical landing with battery power: https://www.beta.team/aircraft/. It's larger than you are interested in, but gives an idea of what can be done with batteries and electric motors. They claim a useful load of 1400 lbs or six people. And it has a wing, so could glide to a landing on a total power loss.
If you search the N number (N250UT), it has flown several 1.5 to 2.0 hour flights recently.
WITW? They do indeed claim VTO on their website, but how? I don't see any pics of the configuration for VTO on their website, and don't see any way to either tilt that aircraft onto its tail (plus the tail rotor is way too small for a balanced VTO), or to tilt the rotor.
How does it take off vertically?
Likes russ_watters and pbuk
It looks like it is actually a quad-copter. It doesn't sit on its tail. In the photos, you can see 4 rotors aligned with the two front-to-back braces on the sides. The rotor on the tail is for forward motion after the vertical takeoff.
If it works, why isn't there a video of it working?
  • Love
Likes russ_watters and berkeman
Ask and ye shall receive:
The V-22 Osprey, One of the most maligned aircraft in history.
Likes russ_watters and FactChecker
And the AV-8B Harrier:
Vectored thrust engine.
Likes FactChecker
You must have X-ray vision or something --- I can't see anything like that
No, not the V22 or Harrier: I have seen at least one of those in VTOL mode with my own eyes. However I was referring to the scam design presented in #7: I don't see any evidence that the fraudsters engineers have produced a working model that can VTOL, and there is no evidence of rotors on the images of N250UT.
The first photo on their website is clearer. You can see the 4 rotors, but they blend in well.
Yes, funny how CGI always looks clearer.
Weird. I see that now in the line drawing and overhead pic with the rotors aligned front-to-back for aero flight forward, but the pictures on their website show only bumps in those two braces, not rotors in the test flights.
Likes russ_watters
It's not clear how far along they are in development. It looks like they have a flying plane without the rotors and the final goal is to get vertical takeoff with rotors. But It looks to me as though they still have work to do.
They are showing you two pictures, one of an aircraft with little bumps on its wings that can fly, and one of a model (or CGI mockup) of something with 4 "rotors" for which there is no evidence, or indeed direct claim, of its ability to fly. The association of the picture with the thing that flies is deliberately deceptive, and this deception clearly fools at least some of the people at least some of the time.
Likes Motore
About as far as I am with my warp drive - look, here's a picture
Yes, I have a flying plane without the warp drive.
No s**t.
  • Haha
Likes Oldman too, Klystron, 256bits and 1 other person
I do not fault them for proceeding in a cautious, step-by-step development. They are just showing some of their work and ideas. I think the first photo is of a model. It's a concept that definitely can work eventually, but the devil is in the details.
  • Sad
  • Wow
Woo-hoo! I'll buy a ride on that baby! How much, and what star date should I put on my calendar? Will I be able to meet Scotty? :smile:
  • Haha
Likes pbuk
It seems to me that they have skipped straight from blue sky thinking to marketing, without even bothering with a proof of concept.
Then why aren't they saying that?
FactChecker said:
It's a concept that definitely can work eventually.
As is my dilithium crystal warp drive.
Yeah, those damn details. Evidence is another thing that I find troublesome. Oh and regulators who insist on not deceiving potential investors (of course I don't live in the land of the free to defraud).
Likes Motore
On closer examination, that's exactly where they are right now. They are currently flying it in airplane mode. Flightaware shows a 2 hour 5 minute flight on June 26, 2022. That's impressive for a battery powered airplane.
The concept is vertical takeoff in a quadcopter configuration, then use a fifth motor to move it horizontally. The horizontal velocity generates enough lift from the wing to unload the lift rotors, after which the lift rotors are stopped and stowed. The idea of rotors for vertical takeoff and a separate propeller and wing for horizontal flight appears to have originated with Jay Carter. He built a gyrocopter with a wing to demonstrate the concept, and was able to show proof of concept: http://carteraero.com/home2/ and https://en.wikipedia.org/wiki/CarterCopter.
On the other hand, Joby Aviation has a more conventional quadcopter design with tilting motors: https://evtol.com/news/joby-evtol-aircraft-surpasses-150-miles-flight-test/. Since then, it crashed due to a "component failure". But it was flying that day: https://globe.adsbexchange.com/?icao=a6df63&lat=35.882&lon=-121.198&zoom=12.5&showTrace=2022-02-16. Search the N-number N542AJ for more information.
Likes FactChecker and berkeman
You are either embracing or dangerously flirting with the Rocket Pendulum Fallacy. The pendulum rocket fallacy is the incorrect idea that a top mounted rocket will make the vehicle more stable than a bottom mounted rocket. Robert Goddard's early "puller" rockets were not more stable than the later "pusher" ones. In either case it is the misaligned rocket that supplies unwanted torque, not gravity. Goddard clearly figured this out early.
Likes Klystron, jbriggs444, russ_watters and 1 other person
Source? It takes no effort for me to hold a stick in a vertical position with my fingertips. It takes constant concentration and feedback control for me to balance that same stick in the palm of my hand and keep it vertical...
I see it as just a webpage to represent their company. They are a small company. Apparently, they have a military contract to develop a quad-copter that converts to regular airplane flight. This is not unusual.
They are just showing where it is heading. They are not asking you for $, so it's not a con job.
A gross exaggeration. This concept is very realistic. There have been several similar efforts. When battery technology improves, it might be a real winner.
I assume that a serious investor can get a lot more information. (Their current effort has military funding.)
I stand corrected. It is more complicated than I indicated.
Still, it seems to me that the vectoring required to correct a lateral disturbance is better if it points in the desired direction of motion. That seems true in a "puller" position but false in a "pusher" position.
Source?
Here's one. https://second.wiki/wiki/falacia_del_cohete_pc3a9ndulo
And a video
The crux here is that the thrust vector for a rocket is rigidly attached to the rocket. If you could always pull the nose up then you would stabilize but that is not easy to do. Goddard figured this out pretty quickly as I recall. (I read his biography 60 years ago! )
  • #31
And a video
A first thought:
If the thrust is stabilized to always point in the desired direction of travel, the "puller" position would have some stability. A "pusher" position would require the vectoring to point even farther from the desired direction than the rocket is pointing.
Of course, if the steering is done with fins, then vectored thrust is not an issue. It might not take much velocity for the aerodynamic forces to be more powerful than thrust vectoring.
Likes Klystron and berkeman
  • #32
And a video
I didn't click into the video yet (late work night here at home), but why is the rocket engine so high in the structure? Is it above or below the COM of the structure, and why is that position important (trick question...)?
  • #33
Assume the force from the rocket is "applied" (by the fuel) at roughly the nozzle throat and along the motor axis. Then the torque will depend upon the closest approach of that line to the Center of Mass for a given gimbal angle. Meaning how far is the throat from the CoM. I think the bottom mounted engine will usually give more control authority. In an active control situatiuon that might be desirable...(?)
  • #34
Yeah, but what happens when your electronic systems fail and you want to switch to manual control...?
https://en.wikipedia.org/wiki/Grumman_X-29
You yell bad words and pull the Eject handles...!
Likes Hornbein
  • #35
It is definitely above the CoM of this rocket (much of the structure is launch tower. That position matters only to determine the sign and magnitude of the active control parameters. If your alignment is sloppy you want that distance large and big aero fins.
I was going to make a (Boeing) comment about whether the X29 came with a software description manual but I won't because in fact Grumman built it ! I'll bet that thing would just uncork...but the F117 is unconditionally unstable too I believe
Likes berkeman
  • #36
Given that a pulling engine is shooting hot exhaust at the payload, I assume that the original experimenters really were fooled about the stability, or they would have put the engine at the bottom.
Likes Lnewqban and russ_watters
  • #37
Instability is not uncommon in a modern fighter. In certain flight conditions, the F-16 is unstable. The flight control system is necessary to keep it flying. There are a lot of redundancies and safety checks built into its flight control.
Likes Klystron, hutchphd, Lnewqban and 1 other person
  • #38
No s**t.
+1 on this. What I see in the photos is a funny-looking plane that looks like it was built on a helicopter body, and that's it. At first I was thinking the rotors might retract into the booms, but, as you say, if it works, just show a video of it working. So I would conclude as well that what we are seeing here is just marketing BS designed to hook investors. Right now it appears they are testing a short-range battery powered plane and that's it. Will they succeed in their ambitious plan of making it VTOL? Nobody has succeeded yet at either goal, but maybe they will be the first not to fail at both simultaneously?
As always the main issue with battery-powered aircraft is the weight of the batteries. For this 7,000 lb craft, more than half will need to be batteries. One wonders whether they'd be better off trying to prove the VTOL part can work by making an all gas or gas-electric version first.
Likes Klystron
  • #39
The force vector from the hand points up, and not along the axis of the broomstick.
If the broomstick does tilt due to whatever reason ( try to place and balance of a stick on its end on a table and it will tilt and fall over ), the hand force vector still points up, providing a torque to the stick and the stick rotates more, To compensate you move the hand sideways in the direction of the tilt.
The rocket engine has its force vector 'always' pointing along the rocket axis and can never provides a torque to the rocket. Gravity cannot provide a torque since all parts of the rocket fall at the same rate ( ie are attracted to the Earth ) , including the engine.
Top or bottom engine amounts to the same thing.
try visualizing a rocket in space without air currents or air drag to see the effects of top-bottom engine behavior and determine if either would give different results.
  • #40
As it happens, I visited the Smithsonian Air and Space Museum annex at Dulles, viewed a re-creation of his first rocket, explained why he designed it that way and explained fallacy to my friend this afternoon. Here it is:
https://en.wikipedia.org/wiki/Robert_H._Goddard#First_liquid-fueled_flight
https://en-academic.com/dic.nsf/enwiki/1272265
Likes hutchphd and FactChecker
  • #41
After watching some videos: they are testing flight efficiency, VTOL configuration "will be tested later". Whatever it means.
Likes russ_watters, FactChecker and berkeman
  • #42
What a coincidence. Beta Technologies is a local story for me. I'm posting right now 400m away from Beta's office/factory. They have certification for the aircraft, the factory, and the inspection techniques. My daughter tends the gardens of the Beta executives, and she promised to introduce me to them real soon now.
Like SpaceX, like Edison's power company, Beta's plans include the entire infrastructure, not just the aircraft. Infrastructure include recharging, maintenance and service facilities, and simulator training, manufacture of the body, batteries and control electronics. They are starting with local package delivery, and organ transplant delivery, but eventually their target it urban taxis.
This picture if from July 3. They did a flyby before the fireworks show in Burlington, VT.
This video let's you see more details of this very unique design. It is not easily comparable to anything else.
  • #43
I think that battery technology will make giant strides in the next couple of decades and battery-powered flight will benefit. The VTOL aspect has been actively pursued for a while.
Likes russ_watters
  • #45
Hi H,
There are jet engined helicopters, if that suits.
Camerart
Likes russ_watters
  • #46
It seems to me that because of the Goddard paradox the stability of would be the same if the blades were below the body. The stability of the rotor is due to its angular momentum, not from being above the body.
We can call this My Even Nuttier Helicopter Idea.
Likes russ_watters and hutchphd
  • #47
Sounds more like a novel lawn mower.
  • Haha
Likes DennisN, berkeman and anorlunda
  • #48
it would work. it's just not better for now.
  • #49
the reason that vehicles are more stable with the "foot" above the mass of the vehicle, is that when hanging, as long as upright is the most natural attitude, then the vehicle will default to upright, so stabilization can come in the form of "let gravity work". Whereas, with the thrust below the craft, the weight is going to droop from gravity, which will cause it to accelerate towards instead of away from the ground. So, helicopters can zero out from lots of positions, and then end up stable, because they hang from the thrust. But, rockets must actively posture no matter what, which is more difficult, and requires more accurate and precise control .
  • #50
This is wrong: you have fallen victim of the pendulum fallacy.
