Heat and Mass Proportionality: Examining the Accuracy
The discussion centers on the relationship between the mass of a liquid and the time required to convert it to gas under constant heat supply. It asserts that the time is directly proportional to the mass, given that the heat supplied remains constant. The equation presented, t = m^2(l + cθ), raises questions about the meaning of the variables involved, specifically m (mass), c (specific heat capacity), θ (temperature change), and l (latent heat of vaporization). Clarification is sought on how these variables interact and their implications for the boiling process. Overall, the accuracy of the proportionality and the equation's structure is under scrutiny.
latyph
I NOTICED THAT THE TIME REQUIRED FOR A GIVEN MASS OF A LIQUID IS PROPORTIONAL DIRECTLY TO THE MASS OF THE LIQUID PROVIDED THE HEAT SUPPLY IS CONSTANT,WHICH MAKES t PROPORTIONAL TO m,the heat is constant.now heat is mctheta +ml.which makes t =m^2(l+ctheta).how true is this,is there a fault i this let me know
given mass of liquid to change to gas to be precised,i made a mistake typin
Okay, every liquid has a "heat of boiling" that is the amount of heat required to change 1 gram of the liquid, already at the boiling point into gas. In order to boil x grams of liquid, you must supply a specific number of calories of heat. If you are providing the heat at a constant rate, then the time required to convert all of the liquid to gas is proportional to the mass.
However, having said "THE HEAT SUPPLY IS CONSTANT", you then say "now heat is mctheta +ml". I don't understand that. What are the variables? m, c, theta, l?
or is that ctheta[/b]? I would guess that m is the mass, but what are c and theta (or ctheta[/b]) and is l a separate constant or is ml one amount? Please tell us what your symbols mean.
m mass of liquid,c specific heat capacity,theta change in temp.l latent heat of vaporization
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
