Mysterious Window: Force It to Move or Find the Process Name?
  • Thread starter Thread starter grady
    Window
A user is experiencing an issue where a window appears at the bottom of the screen and cannot be moved, raising concerns about potential hacking. To troubleshoot, it is recommended to close all applications and use ALT + TAB to bring the problematic window to the forefront of the task manager. From there, the user should note the window's name and attempt to close it through the task manager. If the window is unmovable, it may be an advertisement pop-up generated by websites. Users are advised to check the startup folder for any matching program names and ensure that the taskbar is set to "always on top." For persistent issues, programming solutions can be employed to hide the window automatically. Additionally, a search of the registry may help locate the source of the window. While the presence of a firewall reduces the likelihood of hacking, it is still important to investigate and remove any suspicious programs.
grady
Why is the top of this window appearing at the bottom of the screen? Am I being HACKED! OMG I can't move the window and there isn't anything but the normal spyware that the cable company installs in the task manager. Does anyone know how to force a window to move or how I might link this window to a process name?
http://members.cox.net/gradyfield/hacked.jpg
Computer science news on Phys.org
First thing I'd do is close all applications.
Press ALT and TAB to switch to that bring the mystery window to the top of the task manager list.
Then, hit CTRL-ALT-DEL to bring up the task manager.
Record the name of the open window, which hopefully will be at the top of the list in Task Manager. Then, using task manager, close the window.
Look in your startup folder under program files and see if anything matching that window name is in there.
I take it you are not able to move the window into view. I've seen things like this, seems a lot of times it is just an auto advertisment loader that sites launch on your pc as a popup window so that they can bombard you with advertisment popups.
Tell me this, do you get a lot of adverts?
Thanks for the tip on the task manager. I didn't know the current window was put at the top. The window isn't movable, and if I right click it, Move and Restore (faded out ) are on the menu. If i click move, the 4 directional arrow comes up for a second or two and the window disappears.
I have a firewall installed, so even if it were a program to beckon popup adds to the desktop, either it or they would be stopped I think. The next time the window comes up i'll tell you what the process name is, it comes up at least once a day.
If what annoys you is seeing the window, and not is precense, you can :
1-Check that the taskbar's always on top is enabled.
2-Use a program to catch the window's ClassName, then make a program to hide that window on start up (programatically). This can be done in VB (if it really annoys you, i can do this for you).
Originally posted by grady
Thanks for the tip on the task manager...
How did task manager identify the window?
PROGRAMMING TO GET RID OF SPAM Talk about swatting a fly with a tank! Just control,alt,del and get the file name. Do a search both through start>find> files or folders, and also do a search of the registry. You can do this by going to start> run and typing in regedit. Then hit F3, which brings up the search menu, and do a search for the file in there. It's either in the windows startup folder, in the HKLM>SOFTWARE>MICROSOFT>WINDOWS>CURRENT VERSION<RUN directory in the registry, or both.
Edit: not to scare you, but you want to get it off there. Although it's unlikely, it's always possible someone's attempting to hack your PC, though it's unlikely given that you have a firewall.
I came across a video regarding the use of AI/ML to work through complex datasets to determine complicated protein structures. It is a promising and beneficial use of AI/ML. AlphaFold - The Most Useful Thing AI Has Ever Done https://www.ebi.ac.uk/training/online/courses/alphafold/an-introductory-guide-to-its-strengths-and-limitations/what-is-alphafold/ https://en.wikipedia.org/wiki/AlphaFold https://deepmind.google/about/ Edit/update: The AlphaFold article in Nature John Jumper...
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
