Nanoscale electronics and impulse force
In nanoscale electronics, electrons behave similarly to billiard balls, particularly in devices like ballistic electron transistors. The discussion centers on calculating the time required for a vertical force of 8.90·10^-13 N to achieve a deflection angle of 136° after an elastic collision with a wall at 45°. The problem involves breaking down velocity vectors to determine changes in momentum and applying the impulse formula. There is confusion regarding whether the force from the electrodes should be considered an impulse force or an average force. Clarification on this point is sought to solve the problem effectively.
xdctassonx
In nanoscale electronics, electrons can be treated like billiard balls. The figure shows a simple device currently under study in which an electron elastically collides with a rigid wall (a ballistic electron transistor). The green bars represent electrodes that can apply a vertical force of 8.90·10-13 N to the electrons. If an electron initially has velocity components vx = 1.30·105 m/s and vy = 0 and the wall is at 45.0°, the deflection angle θD is 90.0°. How long does the vertical force from the electrodes need to be applied to obtain a deflection angle of 136.°?
v=√(vx^2+vy^2)
Δp=J(impulse force)=F(average)*Δt
We had a similar problem in class where a baseball was pitched over home plate at 5 below the horizontal with a velocity of 40.23m/s and than hit back at 35° above the horizontal with a velocity of 49.17 m/s. the baseball weighed 0.145 kg and the bat made contact for1.2 ms. We solved this one by
Δvx=(49.17 m/s)(cos35°)-(40.23 m/s)(cos185°)=80.35 m/s
Δvy=(49.17 m/s)(sin 35°)-(40.23 m/s)(sin185°)=31.71 m/s
√((80.35 m/s)^2+(31.71 m/s)^2)=86.38 m/s
Δp=mΔv=(0.145 kg)(86.38 m/s)=12.5 kg m/s
and the we used impulse formula to solve for average force:
F(average)=Δp/Δt=(12.5 kg m/s)/0.0012s=10.4 kN
I understand that we had to break up the velocity vectors in order to solve for the change in velocity vectors, because that change will give us change in momentum. However I am really hung up on this problem when it hits a 45° wall. Would the the force applied by the electrodes be the impulse force or average force? If anyone could help me through this that would be great! Thanks!
Here is a picture as well.
Does anyone have any idea?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
