What is the role of control volume in the Navier-Stokes equations?
The discussion highlights recent advancements in addressing the Navier-Stokes equations, particularly regarding the smoothness problem, where progress has been made but a flaw in the mathematics has been identified. The conversation also explores the concept of control volume versus differential elements, emphasizing the significance of understanding these distinctions in the context of fluid dynamics. Various forms of the Navier-Stokes equations—Lagrangian, Eulerian, differential, and integral—are briefly outlined, illustrating their interconnections. The control volume in the integral approach is defined simply as V, indicating its fundamental role in analyzing fluid behavior. Overall, the dialogue underscores ongoing challenges in finding actual solutions to the Navier-Stokes equations.
verdigris
navier-stokes smoothness problem almost solved
Penny Smith has made progress with showing that smooth conditions exist for all time in a domain for the Navier Stokes equations
http://notes.dpdx.net/2006/10/06/penny-smiths-proof-on-the-navier-stokes-equations/
However a flaw was found in the mathematics - hopefully it can be sorted out soon.There's still the problem though of finding actual solutions to the equations!
Thanks for the info on control volume.I was just wondering if in reality there
is a real,if very small size,to the differential element.
It's not a control volume but a differential element (infinitely small). Imagine a cube with sides that measure, in cartesian coordinates \delta x, \delta y and \delta z.
Actually Fred, the NS equations have 4 forms:
Lagrangian (moving frame of reference)
Eulerian (stationary)
..and then...
Differential
Integral
So for example, looking simply at continuity (sorry again for my lack of latex):
Differential Lagrangian:
Dp/Dt + rho*del•V =0
Where D/Dt is the substantial derivative with respect to time
Differential Eulerian:
dp/dt + del•(rho*V) = 0
(note this form is now strongly conservative as all variables are inside of a derivative)
Integral Lagrangian:
D/Dt [Volume Integral] rho dV = 0
Integral Eulerian:
d/dt [Volume Integral] rho dV + [surface integral] rho*V dS = 0
The entire equations can be derived any of the four ways. It's easiest (at least for me) to remember one form, and then how to go from one form to another.
To answer the question, the control volume for an integral approach is simply V, there is no need to know anything else besides that.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
