Need help constructing a wind tunnel
  • Thread starter Thread starter chappy-13
    Wind Wind tunnel
To effectively mount the aerofoil in a basic cardboard wind tunnel, a sturdy yet adjustable mechanism is essential to maintain the angle of attack during airflow. Suggestions include using a pivot system that allows for easy adjustments while ensuring stability against wind pressure. The setup should facilitate the attachment of a fishing line for accurate lift measurement with a balance scale. The experiment aims to determine critical angles of attack and the angle producing zero lift. Overall, the design must balance sturdiness with adjustability for precise measurements.
chappy-13
i'm currently building a wind tunnel for year 11 physics and need help mounting the aerofoil. The wind tunnel is basic (just cardboard and is circular), and i need a way to mount the aerofoil inside. The mounting has to be sturdy so that the aerofoil can have an adjustable angle of attack and will keep the same angle of attack when the fan is blowing on it, however it needs to be relatively free so that i can measure the lift using a fishing line which is attached to a triple beam balance or spring balance/scale.
any ideas?
p.s the aim of the experiment is to determine critical angle of attack, and angle of attack which produces zero lift, etc
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Venus does not have a magnetosphere, so the Galactic Cosmic Rays (GCRs) environment shall be much worse than in a LEO environment. Looking to the std radiation models for Venus, the standard radiation-hard space level electronic component with tested immunity LET = 85 MeV-cm2/mg seems not enough, so, for example, a 1cm2 Si die will suffer considerable flux above this level during a long mission (10 years for example). So, the question is, usually we are not paying attention to latch-up...
