Need help determining whether to use cosine or sine
  • Thread starter Thread starter physicsnoob145
    Cosine Sine
Understanding when to use sine or cosine in physics problems involves recognizing the relationship between angles and the components of forces. The weight (mg) acts as the hypotenuse in a right triangle, with the cosine component (mgcosβ) representing the adjacent side and the sine component (mgsinβ) representing the opposite side. Visualizing the angle at zero helps clarify that the cosine component is maximum while the sine component is zero. Constructing a triangle with mg as the hypotenuse aids in determining which function to use based on the angle. This foundational understanding is crucial for solving problems involving inclined planes and forces.
physicsnoob145
I'm having trouble understanding when to use sine or cosine in my physics problems
for example I got this from one of the lectures off youtube
and I know why they are using sine and cos because it is at an angle but I'm rotating the angle to understand why it is mgcosbeta and why the other is mgsinbeta and not the other way around
could someone explain to me why it is mgcosbetahttp://img213.imageshack.us/img213/8798/91559741.png
Mathematics news on Phys.org
Visualize what it looks like when the angle is set to 0. One will be 0 and the other will be mg. The one that is 0 is sin and the one that is mg is cos. That will always work.
It helps to understand this if you construct a triangle with mg as the hypotenuse, then it becomes clear when to use sin or cosine.
thank you it is a little clearer now
Just as rcgldr has shown the weight must always be the hypotenuse as it is largest force acting.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
