Need help finding what formula to use?
  • Thread starter Thread starter maegenr8
    Formula
To determine the maximum height a tennis ball reaches when hit at an initial velocity of 26 m/s at a 54-degree angle, the relevant formula is v^2 = v_o^2 + 2aΔy. At the peak of its trajectory, the vertical velocity is zero, so this value is used in the equation. The initial vertical velocity calculated is 21.0 m/s, and the acceleration due to gravity is -9.8 m/s^2. By substituting these values into the formula, the correct height of 22.6 meters can be derived. The discussion emphasizes the importance of using the correct initial vertical velocity for accurate calculations.
maegenr8
A tennis player hits a ball at ground level, giving it an initial velocity of 26 m/s^2 at 54 degrees above the horizontal. How high above the ground does the ball go?
I found out the horizontal velocity, which is 15.3 and the vertical velocity which is 21.0
In projectile motion the highest point occurs right in the middle when the vertical speed is zero.
Yeah, I understand that. What formula would I use to actually find the height though?
v^2=v_o^2+2a\Delta y
So if at the highest point there is a vertical speed of zero, would I put zero in for v^2? 26 for initial velocity and -9.8 for acceleration?
Yes.
the answer is 22.6, but when i do that I get 34.49
ohh... I think I needed to put in the vertical velocity which was 21.0 instead. Then that formula works.
