Need help regarding shaft material
  • Thread starter Thread starter CrayonK
    Material Shaft
Acrylic may not be suitable for an accumulator shaft in a trike due to its potential inability to withstand the necessary torque and stress. Concerns were raised about the durability of acrylic compared to metal, especially for holding components like a cycle ratchet and sprocket. The weight advantage of acrylic is noted, but a hollow metal shaft could offer similar weight while providing better strength. Additional details about the trike's size, power source, and drive shaft length are needed for a more informed recommendation. Overall, a metal shaft is suggested as a more reliable option.
CrayonK
I'm building a trike and wanted to know if an acrylic shaft would suffice? The accumulator shaft would hold two cycle ratchet and a sprocket.
The main reason behind going for acrylic is the weightlessness.
Welcome to the PF.
What's a "trike"? I assume it's a 3-wheeled something, but how big is it? How is it powered? How long is the drive shaft? How much torque does the shaft need to withstand?
Using a hollow metal drive shaft would probably work better than a solid acrylic shaft, and would probably weigh about the same...
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
