Need help with a Very Hard Kinematics Qn
  • Thread starter Thread starter physicsnoob93
    Hard Kinematics
physicsnoob93
Imagine a tank traveling at constant speed v1 along direction AB and a missile is chasing the tank with constant speed v2. The direction of motion of the missile is always pointing toward the tank. At the t the tank is at position F and the missile is at position D, where FD is perpendicular to AB and FD = L. What is the acceleration of the missile at this instant?
A---------------F---------------B
************D
I have no clue, i have spent hours on this qn. I tried drawing the initial and final velocity vectors for the missile but i have no idea how to continue from there.
Thanks if anyone can help.
Acceleration is a change in velocity with respect to time. The missle velocity relative to the tank is v2 - v1. There is no linear accleration in this problem. Are you trying to solve for the angular acceleration?
Its best to use relative coordinates.
Lets fix our system to the tank, and use polar coordinates, so r will be the instantaneous distance between the missile and the tank, and \phi will be the angle between this and the initial position.
Our equations are then:
\dot r=v_2-v_1\sin\varphi
and
r\dot\varphi=v_1\cos\varphi
Now we know that the acceleration in polar coordinates is:
\vec a = (\ddot r -r\dot\varphi^2)\vec e_{r} + (2\dot r\dot\varphi + r\ddot\varphi)\vec e_{\varphi}
Using the equations, calculate the acceleration, and after you are done put \varphi=0 and r=L, and you will get it at the beginning.
It turns out to be:
a=\frac{v_1v_2}{L}
(I be wrong, because I just scribbled it up quickly... :D)
Thanks for the replies. I solved it using similar triangles and i got v1v2/L too.
My Solution is:
If there's a triangle drawn for the distance,
Theres the adjacent with l and the opposite to be V1*dt
If there's a triangle for velocity,
The adjacent is V2, the opposite is a*dt
Then we get
V1dt/l = adt/V2
Simplifying,
a = V1V2/l
Thanks though :D
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
