Calculate X-Component of Electric Field at Origin | Integral Homework Help
  • Thread starter Thread starter yeahhyeahyeah
    Integral
The discussion focuses on calculating the x-component of the electric field at the origin due to a semicircular charge distribution. Participants express confusion over the integration of charge density, specifically why dq is replaced with λR instead of λds. It is clarified that while dq=λds is correct, ds must be related to the radius and the angle θ for proper integration. The cancellation of components from different quadrants is also debated, with emphasis on the relevance of the x-component in this context. Understanding the relationship between ds, R, and θ is crucial for solving the problem correctly.
yeahhyeahyeah
In the picture given to me, 3/4 of a circle is drawn around the origin. Basically every quadrant but the first. The radius is R and the charge density is λ. It says, find the x-component of the electric field on a point charge at the origin.
I integrate coulomb's law so I get
∫kdq/r^2cos(Θ) where Θ goes from pi/2 to pi, because the bottom two quadrants cancel each other out
Now, the solutions given say to do
dq = λR
why do I replace dq with λR ?? I'm very confused about what I'm doing
if q = λ2piR
shouldn't dq= λ ds where ds goes from 0 to 2piR, so why the heck does that give me the wrong answer, why is it just dq = λR, I don't understand why the charge density can just be multiplied by the radius, what does that give you? Shouldn't it be multiplied by the actual length of that bit, as in λ2piR or however much of the circumfrence is being used?
Wouldn't it be rather the second and fourth quadrants who cancel each other out?
Err... well I think if I was looking at both x and y components then yes, but as I'm only finding the x component of the E field it doesn't really matter, either of the quadrants on the left can cancel out the one on the right, but you're right, the y's of the fourth are canceled by the y's of the secnod
dq = λR
Well, that's not quite right. Almost, but not completely right.
if q = λ2piR
shouldn't dq= λ ds
dq= λ ds is correct.
Now, can you related "ds" to R and something to do with the angle θ? Drawing a figure with ds would probably help with this.
Yes, λ should be multiplied by the length of the bit, "ds". See my hint/question above.
