Need help with comparison method for improper integral?
mottov2
\int \frac{arctan(x)}{2+e^x}dx
where the interval of the integrand is from 0 to infinity.
In order to use the comparison method I need to compare 2 functions but I am having so much difficulty figuring out what function to compare it to.
Its not just this particular question, any question asking to use comparison method, I can't seem to figure out the function to compare it to.
Can I get some tips to finding a function to compare it to?
tan-1(x) < 2 for all x, so therefore...
\frac{tan^{-1}(x)}{2 + e^{x}} &lt; \frac{2}{2 + e^{x}}
for all x (Since 2+ex is never 0, one doesn't have to worry about division by zero.)
So try using the comparison test with that.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
