What Happens to ln[(x+2)/(x-1)] as x Approaches -2 from the Left?
  • Thread starter Thread starter gillgill
    Limit
As x approaches -2 from the left, the limit of ln[(x + 2)/(x - 1)] is evaluated. The numerator approaches 0 while the denominator approaches -3, leading to a limit of negative infinity. Conversely, as x approaches -2 from the right, the numerator remains positive and the denominator negative, indicating the ratio approaches a negative value. Taking the natural logarithm of a negative quantity results in an undefined expression. Thus, the function exhibits divergent behavior as x approaches -2 from either side.
gillgill
i have done part of the work
but i got stuck here
what is
lim f(x) = lim ln [(x + 2)/(x - 1)] =?
x→-2- x→-2-
how do u solve for this?
What is:
\lim_{x \rightarrow -2 ^ -} \frac{x + 2}{x - 1}? Note that the numerator tends to 0, while the denominator tends to -3.
Then what can you say about:
\lim_{x \rightarrow 0 ^ +} \ln x?
Viet Dao,
that would be -infinity??
how about
x→-2+ x→-2+
Obviously, the numerator and denominator will separately approach the same values, so the ratio will also approach the same value. However, notice that in this case, the numerator will always be positive while the denominator will be negative. What does that tell you about the ratio? And what happens when you take the natural log of such a quantity? So, what can you say about the function when you try to take this limit?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
