How Far Will You Travel Before Catching Up with the Biker?
  • Thread starter Thread starter Butterfly30
    Motion
The discussion revolves around a physics problem involving a car accelerating from rest at 3 m/s² to catch up with a biker traveling at a constant speed of 9 m/s. Participants suggest using kinematic equations to equate the displacements of both the car and the biker over time. The approach includes calculating the time it takes for the car to catch up by setting the distance equations equal and solving for the time variable. Additionally, there is mention of drawing velocity-time diagrams to visualize the motion and using the areas under the curves to determine when the car catches the biker. The key to solving the problem lies in correctly applying the equations of motion for both the car and the biker.
Butterfly30
Need help with "motion" question..please!
you are sitting in a car that is stopped. The moment a biker passes you, you start accelerating at 3 m/s2, while the bicycle continues to move along at a constant speed of 9 m/s. After what distance will you catch up with the biker?
From the question, the info I have is v=9m/s V0=0 a=3m/s*2
So I think I would put it into V=V0+at and solve for t. Then use all info including the new t into x=x0+v0+1/2at*2
I keep getting it wrong...any ideas?
suppose after tsec , the biker is caught.
equate the displacements , and find necesary condition for quadratic to be real .
Draw the v-t diagram for your motion and the bikers motion.
Your motion is a triangle, the bikers is flat.
You need the time when the areas under the graphs (you know how to find the area of a triangle right?) are equal.
You could also find the equation for the distance between the bike and the car at time t, then find the time that this distance is zero.
If the bike goes at a constant speed v - what is the equation for it's displacement with time?
If the car has a uniform acceleration of a, from rest, what is the equation for it's displacement with time?
Subtract these two.
Off what you did:
... presumably for the car: what did you use for the final speed of the car? (note: it will be going much faster than the bike when it catches up.)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
