I Need help with some calculations with gravitational waves
The discussion focuses on the calculations related to the first discovery of gravitational waves, specifically regarding the masses of merging black holes, the energy radiated, and the distance of the event. The "chirp mass" is determined from the frequency and its rate of change, which helps estimate the individual black hole masses through numerical modeling based on General Relativity. The energy radiated during the merger is calculated using General Relativity models that incorporate the identified masses. The distance to the event is inferred by comparing the signal's amplitude with theoretical values for a given energy output. Further details are available in a subsequent paper that explores the properties of the binary black hole merger.
Meerio
I have some questions about the first discovery paper that was released about gravitational waves, especially some of the maths.
How did they:
1. Calculate the masses of the black holes that merged
2. Calculate the energy radiated away in gravitational waves
3. Calculate how far away the event happened
(I assume the third can be calculated with a formula that involves amplitude, but I am yet to find the right formula's for any of these)
Sorry if this is easily solvible but I couldn't find the answers myself.
Paper: https://physics.aps.org/featured-article-pdf/10.1103/PhysRevLett.116.061102
Astronomy news on Phys.org
I think this is probably how it was done:
1. As mentioned in the paper, the frequency and rate of change of frequency determine the "chirp mass" which gives the basic mass scale. Numeric modelling based on General Relativity with varying parameters is used to recreate the shape of the wave form in figure 2 to give the likely individual masses.
2. The radiated energy is estimated using General Relativity from a model of the merger given the identified masses.
3. The amplitude of the signal is compared with the theoretical amplitude at a given distance for that amount of energy to establish the approximate distance.
Likes Meerio
Thank you very much if anyone knows whether this is true or not please confirm!
What is the angle between the orbital plane of the binary hole, and the direction to Earth?
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
