Need help with structure of stair climbing robot
  • Thread starter Thread starter Umair Mazhar
    Robot Structure
The discussion focuses on designing a stair-climbing robot, highlighting challenges with the mechanical structure compared to electrical and programming aspects. Key insights suggest that two motors are positioned centrally to facilitate sliding motion, possibly using a belt or chain system. The motion could also be achieved through a rack and pinion design, offering an alternative to the belt mechanism. There is uncertainty regarding motor attachment to the wheels, which remains a point of confusion. Overall, the conversation emphasizes the need for clarity on the mechanical components to achieve effective movement.
Umair Mazhar
Im supposed 2 design a robo like this 1, but here, the mechanical part seems more tought thn the electrical and programming. I couldn’t make out what mechanical structure is being used to have this type of motion. Can anyone please help.
Here’s a start:
There r 2 motors attached in the centre part of the robot, which keeps sliding back anf forth.
But, I can’t figure out out is the motor shaft being coupled to the structure, and how does it have tht kinda motion.
The sliding motion looks to be from a belt or chain. Utilizing a stepper motor with a chain or belt would allow you to count how many steps it takes to move a fixed point on the chain from one end of the track to the other. The fixed point on the chain or belt is attached to a pivoting mechanism (probably another stepper motor) within the body of the robot... inside the track that it slides on is probably a wire ribbon similar to that of the inside of a printer which would power the motors for the wheels. That's just me dissecting it with my eyes though.
OR... if you don't want to use a chain or belt, you can make a rack and pinion design to create the sliding motion.
thnx
i can't see any motors attached to da wheels, r thr motors?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
