Find M in \int_{-\frac{\pi}{2}}^{M} \cos x dx= 1.5 with Expert Tips
  • Thread starter Thread starter ziddy83
    Integral
To solve the integral \(\int_{-\frac{\pi}{2}}^{M} \cos x \, dx = 1.5\), the anti-derivative of \(\cos x\) is \(\sin x\). Evaluating this from \(-\frac{\pi}{2}\) to \(M\) gives \(\sin M - (-1) = 1.5\). This simplifies to \(\sin M + 1 = 1.5\), leading to \(\sin M = 0.5\). The solution for \(M\) can be found using the inverse sine function, confirming the calculations.
ziddy83
Hey what's up..I need a little help with the following problem.
If \int_{-\frac{\pi}{2}}^{M} \cos x dx= 1.5}, find M.
How do I go about doing this? I know that...the anti derivative of cos is sin, and that \sin x \right]_{-\frac{pi}{2}}^{M} = 1.5
Any help would be greatly appreciated...
\sin x |^M_{-\pi/2} = \sin M - (-\pi/2) = 1.5
Are you ok from there?
ahhh..DUH! goshh...how did i NOT see that? Thanks man...haha...
It was a typo/error in post #2.
\sin x\left |_{-\frac{\pi}{2}}^{M}\right =1.5\Rightarrow \sin M+\sin\frac{\pi}{2}=1.5\Rightarrow \sin M +1 =1.5
Daniel.
Oops! You're right, of course.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
