How Do You Measure Vibration Decay in Damped Drumsticks?
To measure vibration decay in damped drumsticks, it's recommended to support the stick in a way that mimics how a drummer holds it, as this will provide more relevant results. An effective excitation method is the "plink" test, where the end of the stick is plucked to induce an instantaneous impact, allowing for analysis of natural frequencies. Using an accelerometer along the stick's length or a specialized microphone placed close to the stick can yield accurate measurements of vibration amplitude and decay rate. These methods help minimize human error and provide clear data for analysis. Proper experimental design is crucial to ensure that boundary conditions do not affect the results.
noodles1
Hi,
I am currently in the process of completing my final year mechanical engineering thesis, which compares the dynamics of damped drumsticks (not the chicken ones, the drum kit playing ones!) with those of a conventional, undamped drum stick.
I now am up to the point where I need to devise an experiment to measure the intensity/amplitude of vibrations and also the time they take to decay. Where I am having trouble is my inexperience with experimental equipment and know-how.
Some issues I can see myself having are;
How to support the drumstick?
- I figure I can either clamp the stick at either the end or where a drummer would grip the stick, or support it using thin string or wires that are attached to a structure above the stick.
Would one of those methods be better than the other and why?
Excitation Device
- All I can think of is possibly an impact hammer and measure the subsequent reactions of the stick, however I am concerned that this might add a degree of human error.
Would this be the best way to excite the stick?
I am also having concerns about the weight of the drumstick and it relative light weight, compared to the force it is being struck with.
Is there anything else I should look at? What would be the best way to measure the amplitude and rate of decay of the vibrations in the stick?
Welcome to my world. Testing takes a bit of a different eye.
When it comes to supporting the drumstick, either way you presented would be arguably correct. I always try to fashion my tests the way the item is actually used. So I would argue to clamp the stick in a fashion that is closest to being held by a human hand. However, you do need to take a look at what effects that boundary condition will have on your results. Just make sure that what you are wanting to see will not be lost because of it.
In terms of the excitation, it seems to me that you want to do what we call a "plink" test. You want to induce a s close to an instantaneous impact and watch for the results. We do that with turbine and compressor blades when we want to look for their natural frequencies. Essentially, with the stick very rigidly mounted, you "pluck" the end of the stick. This can be controlled by the initial deflection that you induce in the stick from its equilibrium point. It's kind of hokie, but the results are good. Plus it is very simple and requires no outside equipment to have to contend with.
The best bet for measurement would be an accelerometer or multiples along the length. That would be more in line of a modal analysis. The other thing you could do, and is what we do, it to use a specialized microphone in VERY close proximity to the object. The microphone will pick up the tip vibrations that can be sent to an analyzer.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
