What is the Impact Angle Equation for Colliding Objects at an Angle?
  • Thread starter Thread starter JenadaeX
    Angle Impact
The discussion centers on the impact dynamics of colliding objects at an angle, specifically focusing on how momentum is transferred during a collision. When Object A, described as a pole, collides with Object B, which is losing momentum, Object B will indeed lose further momentum upon impact. The angle of impact can cause Object A to fall at an angle if the upper part of Object A exerts enough force on the lower part. The conversation also explores how a knife thrown at a solid box affects the box's structural integrity, with the outcome depending on the knife's trajectory and spin. Ultimately, the discussion highlights the complexities of momentum transfer and impact angles in collisions.
JenadaeX
ok i got a question that has come up at work today and we can't come to a answer we all agree on, i won't go into the reason this question came up unless i can't answer questions about it without referencing it so here we go
if object A a poll like object as wide as a Object B hits Object be being previously thrown at it at a straight angle losing momentum already as it hits object B, as the objects collided with object A, object B will lose mementum(correct?) causeing Object As impact to be curved(correct?) thus when the upper part of object A to fall down apon the lower part at a angle(correct?) now the impact from (now upper A(UA) and bottom A(BA)) UA is to great for BA to resist causeing it to fall.. would this make A fall at a angle?
can you try to clarify that problem, break it down to its simplest terms, and try to avoid superfluous details. I am not trying to be critical, but you question can be answered better if you do that.
kk let me try the best i can
i throw a knife at a solid box , it doesn't go all the way through
Q1) would this knife lose momentum passing through the box? or is all momentum lost at once?
Q2) does the impact cause a straight line of damage or it make it at a angle like < that
the solid box is a cube figure let's say 10 feet tall, (this only implys if the damage was at a angle) the top half of the box lands on the bottom half, the bottom half can't support the top half and crumbles.
Q3) would this box fall into itself or would it crumble at a angle?
-1- a.
-2- Depends on how the knife was thrown. Traditional throw with spin, you get a non-straight channel. Shot somehow straight at the cube with no spin, you get a straight channel.
-3- How does a little bitty knife cut a 10 foot cube in half?
-1- a.
it does... lol buy not at a angle it hits str8
