Net Electric Field Between Two Point Charges
The discussion focuses on calculating the net electric field E between two point charges, q1 and q2, separated by a distance of 0.10 m. The user attempts to compute E(-0.100) using the electric field equations but receives an incorrect result. Confusion arises regarding the placement of charges and the signs in the calculations, particularly the negative value for the distance and the exponent used for q2. The thread highlights the importance of correctly applying the equations and checking for potential errors in calculations or assumptions about coordinate placement. Clarifying these points is essential for arriving at the correct solution.
Rachelbot12
Two point charges q1 = 4.90×10-5 C and q2 = 2.45×10-4 C are separated by a distance d = 0.10 m. Compute their net electric field E (x) as a function of x for the following positive and negative values of x, taking E to be positive when the vector E points to the right and negative when E points to the left.What is E(-0.100)?
I tried the following equations, but I couldn't get any to work for any of the values of x:
E(x<0)= -k [(Q1/x^2)+(Q2/(d-x)^2]
E(0<x<d)= k [(Q1/x^2)-(Q2/(d-x)^2]
E(d<x)= k [(Q1/x^2)+(Q2/(d-x)^2]
E(-0.100)= -9e9 [(4.90e-5/-0.01)+(2.45e4/0.04)] = -1.1e7 N/C
This is being marked incorrect and I don't know what I'm doing wrong. I've attempted multiple times with no luck.
Does the exercise mention the origin of the x-coordinate ? Your equations place Q1 at x = 0 at Q2 at x = d.
I expect that is OK. But then I don't understand the minus sign before the 0.01
and I also don't understand the 2.45e4 if the charge is 2.45e-4 Coulomb !?
One or more typing / calculator keying errors ?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
