Find Net Electric Field Magnitude & Direction in an Equilateral Triangle
To find the net electric field at the centroid of an equilateral triangle, use the equation for electric field, E = kq/r^2, where k is Coulomb's constant, q is the charge, and r is the distance from the charge to the point of interest. Since the question involves direction, it's essential to treat the electric field as a vector, incorporating both magnitude and direction. The direction can be determined by breaking the electric field into x and y components based on the geometry of the triangle. This approach ensures accurate calculation of the net electric field at the centroid.
kevykevy
Find the magnitude and direction of the net electric field at the centre (or centroid) of the triangle.
The triangle is equilateral and the point of reference is in the middle of the triangle.
What I want to know is what equation do I use to figure this out?
At first I thought it was: Fnet = kq1q2/r^2
Is that right?, if not can you tell what to use?
That's almost right...the question asks for the net electric field, which means you have to use a vector, not just the magnitude as you've shown.
\vec{E} = \frac{kq}{r^2}\hat{r}
Also, how do I find the direction of the field?
Do I have to use some sort of x and y component breakdown?
That's right.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
