Net force, electric field and potential
The discussion revolves around calculating the net force, electric field, and electric potential at the origin due to two particles with 2.00 microcoulombs charges and a test charge of 1.28x10^-18C. For part (a), the net force on the test charge can be determined by calculating the force from each particle and adding them as vectors. Part (b) requires finding the electric field at the origin, which also involves vector addition of the fields from both charges. For part (c), the electric potential can be calculated using the provided equation, considering the distances from the charges to the origin. Overall, understanding vector addition is crucial for solving parts (a) and (b).
tag16
Given two particles with 2.00 microcoulombs charges and a particle with charge q= 1.28x10^-18C at the origin.(a) what is the net force exerted by the two 2.00 microcoulombs charges on the test charge q? (b) What is the electric field at the origin due to the two 2.00 microcoulomb particles? (c) What is the electric potential at the origin due to the two 2.00 microcoulombs particles?
Vp=k(q1/r1+q2/r2)
I have no idea how to do part a and b, but I think just use the above equation for part c correct?
Hi tag16! :wink:
tag16 said:
Given two particles with 2.00 microcoulombs charges …
(erm :redface:where? :confused: … anyway:)
Forces and fields are both vectors, and so they add like vectors, so just find the force (or field) from each particle, and add. :smile:
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
