What are the net ionic equations for these reactions?
  • Thread starter Thread starter Zachalmighty
    Ionic Net
The discussion focuses on deriving net ionic equations for two chemical reactions. For the first reaction between Al(NO3)3 and K2CO3, participants confirm that a precipitate forms and emphasize the importance of solubility rules in determining the net ionic equation. In the second reaction involving hydroiodic acid and CH3NH2, it is noted that no precipitate occurs, indicating an acid-base reaction. Clarifications are made regarding the dissociation of compounds and the definition of concentration, which refers to molarity rather than charge. The conversation highlights the need for understanding limiting reagents and the proper interpretation of ionic dissociation in reactions.
Zachalmighty
1) You mix a 45.0 mL solution of 0.250 M Al(NO3)3* with a 30.0 mL solution of 0.600 M K2C)3. (a) Give the net ionic equation. (b) How many grams of the precipitate forms? (c) After the reaction, what is the concentration of the excess ions?
*All of the numbers in the listed molecules are subscripts.
2. Give the formula equation, the complete ionic equation, and the net ionic equation of the reaction in water between hydroiodic acid and CH3NH2*.
*the numbers here are subscript as well.
a) Al(NO3)3 + K2CO3 ----> AlK2 + NO3 ?
Well, if you know that you are assumed to use solubility rules, I suppose you may check them in your textbook. You may also try to google them:
http://www.google.com/search?q=solubility+rules
In the second reaction there will be no precipitate, this is acid base reaction.
Is it safe to assume that when it says dissociates it means that a compound like NO3would turn into N and 03 or does it simply mean that it breaks with whatever else it is bonded to as the complete compound NO3?
By concentration of the remaining Ions it means whether they are negative or positively charged, right?
Dissociates into Al3+ and NO3-.
No, concentration is amount per volume, charge doesn't matter. For example you may have solution that contains 0.1M (mol/L) Na+.
This is just a limiting reagent question.
Ah, ok. So by concentration they mean Molarity! I should have noticed that. Thank you.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
