New full scale deflection of an ammeter
Bolter
Calculate the new full scale deflection of the ammeter
Rs = iRc/I-i
Question:
My attempt:
Does 4.75 amps for the full scale deflection seem okay?
Thanks for any help!
What kind of help would you like ?
Looks good.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
