New intregral same old problem
  • Thread starter Thread starter Phymath
The discussion revolves around finding the electrostatic potential of a linear charge distribution along a segment on the z-axis. The charge density is defined as λ = aQ/(z² + a²), and the potential at a point on the x-axis is expressed through an integral. Participants suggest different substitutions to simplify the integral, with one proposing a hyperbolic substitution and another suggesting a tangent substitution. Both methods aim to evaluate the integral correctly, leading to the same potential expression. The conversation confirms that the problem is solvable, depending on the preferred substitution method.
Phymath
A stright line segment of length 2L is placed on the z-axis with its midpoint at the origin. The segment has a linear charge density given by...
\lambda = \frac{aQ}{z^2 + a^2}
where Q and a are constants, a>0 find the electrostatic potential of this charge distribution at a point on the x-axis in Cartesian coords.
\Phi = \int_{-L}^{L} \frac{k_e dt \frac{aQ}{t^2+a^2}}{\sqrt{x^2 + t^2}}
= k_e Q a \int_{-L}^{L} \frac{dt}{(t^2 +a^2) \sqrt{t^2 + x^2}}
what do now?...no idea what subsitution will make this work,any suggestions?
Yes,u may put your integral under the form
\Phi=2kQa\int_{0}^{L}\frac{dt}{(t^{2}+a^{2})x\sqrt{\left(\frac{t}{x}\right) ^{2}+1}}
and do the substitution:
\frac{t}{x}=\sinh u
Daniel.
Okay,if you do that substitution,u'll end up with these integrals (actually the second).
Daniel.
ya...instead of that good idea (which it is) how about...
= \frac{k_e Q a}{x} \int_{-L}^{L} \frac{dt}{(t^2 +a^2) \sqrt{(\frac{t}{x})^2 + 1}}, \ \frac{t}{x} = tan(u)
t^2 = x^2 tan^2 (u), \ dt = x sec^2 (u) du
= \frac{k_e Q a}{x} \int_{tan^{-1}(-L/x)}^{tan^{-1}(L/x)} \frac{dt}{(x^2 tan^2 (u) +a^2) \sqrt{tan^2 u + 1}}
= \frac{k_e Q a}{x} \int_{tan^{-1}(-L/x)}^{tan^{-1}(L/x)} \frac{x sec^2 (u) du}{(x^2 tan^2 (u) +a^2) sec(u)}
= k_e Q a \int_{tan^{-1}(-L/x)}^{tan^{-1}(L/x)} \frac{sec (u) du}{(x^2 tan^2 (u) +a^2)}, \ c= \frac{a}{x}
= k_e Q a \int_{tan^{-1}(-L/x)}^{tan^{-1}(L/x)} \frac{sec (u) du}{x^2( tan^2 (u) + c^2)}
= \frac{k_e Q a}{x^2} \int_{tan^{-1}(-L/x)}^{tan^{-1}(L/x)} \frac{sec (u)}{(tan^2 (u) + (\frac{a}{x})^2}
=\frac{2 tan^{-1}(\frac{L\sqrt{x^2-a^2}}{a\sqrt{x^2+L^2}}{1}
does this all look legal? if there's an x^2 in the last one, idk why its there it's not supposed to be...
Correct that latex errors.It looks good.That substitution leads to the same answer.I still prefer hyperbolic trig.functions.
Anyway,your problem is solvable.It depends on u which eq.u prefer most.
Daniel.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
