What is the Formula for Determining Height in Newton's Law of Gravitation?
To determine the height at which a person's weight is reduced to 1/5 of their weight at Earth's surface using Newton's law of gravitation, the gravitational force at the surface must be compared to that at a height h above the surface. The relationship can be expressed as GM_em/r^2 = 1/5 (GM_em)/R_e^2, leading to the equation r^2 = 5R_e^2. This implies that r, the distance from the center of the Earth, equals approximately 2.23 times the Earth's radius, or 14,272 km. The height h can then be calculated as h = r - R_e. The discussion emphasizes that centripetal acceleration is not necessary for solving this problem.
science_rules
Starting with Newton's law of gravitation, determine the height h one person has to go from the surface of Earth in order for the person's weight to be reduced to 1/5 of their weight at the surface of the Earth. The only information you are given is that the radius of the Earth is 6400 km.
GM_e/r^2, r = R_e + h
i know that 4 times R_e at the center(of earth) is equal to 3 times R_e at the surface. I am not sure how to find the height using Newton's Law.
Well, what are you asked to actually compare?
Try to formulate an equation that incorporates this, what you have called equations are not that at all.
hi science_rules
So the problem effectively says the gravitational force at the surface (r1=Re) is 5 times the force at (r2=Re+h). Equivalently you can consider the acceleration due to gravity (why?)
So try writing this out as an equation, then solving for h
a person's weight is dependent on how far out you are from the surface, and the weight is reduced as the distance is increased. should it be some kind of ratio problem? could it be: GM_em/ r^2 = 1/5 (GM_em)/R_e^2
r^2 = 5R_e^2 where r = (squrrt5)R_e = 2.23R_e = 14272 km
a_c = v^2 / r but what does that have to do with the height? you don't know the velocity, but you don't need the velocity to get the height.
post #4 looked good, then h = r - Re
i'm not too sure about post #5, i don't think you need to look at centripetal accleration in this problem
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
