Newton's law of motion problem
In summary, the problem involves an object with a mass of 5.00 kg connected to a cable that passes over a pulley and is then attached to a hanging object with a mass of 10.0 kg. The acceleration of both objects and the tension in the cable need to be determined. Using equations and algebra, the magnitude of the acceleration is found to be the same for both objects and the tension in the cable is calculated to be m1m2/(m1+m2) times the gravitational acceleration.
kfink85
Here is the problem. I think I set it up right but I am stumped now.
An object with mass m1=5.00 kg rests on a frictionless horizontal table and is connected to a cable that passes over a pulley and is then fastened to a hanging object with mass m2=10.0 kg. Find the acceleration of each object and the tension in the cable.
Here is what I came up with:
m1y: N-m1*g=0
N=m1*g
N=-49N
m1x: T=m1*ax
ax=T/m1
m2: T-m2*g=m2*a
(T-m2*g)/m2=a
Help please! This is due tomorrow and I'm stuck. I'm really bad at solving or finding the right step to get to only 1 unknown in equations.
First of all - the N is positive = mg.
Now with each of the blocks you have an equation with two unknowns, the acceleration which is the same with both blocks and the tension which is also the same in both equations. Solving this is just simple algebra. You could do it by using the first equation to find T as a function of a (T=m1*a) and then inserting that (m1*a) into the second equation. Then you will have just one unknown.
You know that the magnitude of acceleration is the same for both masses?
Therefore,
[tex] | {\vec a} | = \frac{{| {m_2 \vec g - \vec T} |}}{{m_2 }} = \frac{{ | {\vec T} | }}{{m_1 }} \Rightarrow[/tex]
[tex]| \vec T | = \frac{{m_1 m_2 }}{{m_1 + m_2 }}| \vec g |[/tex]
[tex]| \vec a | = \frac{{m_2 }}{{m_1 + m_2 }} | \vec g |[/tex]
Now just plug in that m1=5.00 kg and m2=10.0 kg //
(and that [itex]| \vec g |[/itex] = 9.81 m/s2 :smile:)
Thanks very much guys.
1. What is Newton's law of motion?
Newton's law of motion is a set of three laws that describe the relationship between an object's motion and the forces acting upon it. The first law states that an object at rest will remain at rest, and an object in motion will remain in motion at a constant velocity unless acted upon by a net force. The second law states that the acceleration of an object is directly proportional to the net force acting upon it and inversely proportional to its mass. The third law states that for every action, there is an equal and opposite reaction.
2. What is the difference between inertia and acceleration?
Inertia is the tendency of an object to resist changes in its state of motion. It is related to an object's mass and is described by Newton's first law of motion. Acceleration, on the other hand, is the rate of change of an object's velocity over time. It is related to the net force acting on an object and is described by Newton's second law of motion.
3. How can Newton's second law of motion be applied to real-life situations?
Newton's second law of motion can be applied to real-life situations by using the formula F = ma, where F represents the net force acting on an object, m represents the mass of the object, and a represents the acceleration of the object. This formula can be used to calculate the force needed to accelerate an object to a certain velocity, or to calculate the acceleration of an object given a certain force. It is commonly used in areas such as engineering, sports, and transportation.
4. Can Newton's laws of motion be broken or violated?
No, Newton's laws of motion are fundamental principles of physics and have been extensively tested and proven through observation and experimentation. They apply to all objects in the universe and cannot be broken or violated.
5. How does Newton's third law of motion relate to everyday life?
Newtons's third law of motion, which states that for every action, there is an equal and opposite reaction, can be seen in everyday life in many ways. For example, when you push against a wall, the wall pushes back on you with an equal force. In sports, when a soccer player kicks a ball, the ball exerts an equal and opposite force back on the player's foot. This law also explains how rockets are able to launch into space by pushing against the ground with a great force, causing the ground to push back with an equal force, propelling the rocket upwards.
9K
