Newtons Law Problem: objects and pulleys
The discussion revolves around a physics problem involving three blocks connected by cords over frictionless pulleys, with specific masses assigned to each block. The main challenge is determining the tension in the cord on the right side when the blocks are released, given that only masses are provided and no angles are involved. Participants express confusion about how to proceed with the solution without additional information, particularly angles that could help set up equations. The conversation encourages exploring what other factors or equations might be necessary to find the tension. Overall, the thread highlights the importance of understanding the relationships between the masses and the forces acting on the system to solve the problem effectively.
wegman14
three blocks attatched by cords that loop over frictionless pulleys. Block B lies on frictionless table, block a hangs off the left side of the table, while block c hangs off the right side. mass a= 6kg mass b= 8kg and mass c= 10kg. When the blocks are released, what is the tension in the cord at the right?
F=ma
Tension force= mgcos0
i don't really have an attempt at the solution, i don't see where to go when only given the masses of the objects. Also, there is no angles involved so it eliminates some of my equations
What else do you feel you need apart from the masses to proceed toward a solution? If angles had been given, how would you have set up the equations? Give an example, so that we can consider it further.
