Newton's Law question, Not sure if right
  • Thread starter Thread starter BreakPoint
    Law Newton's law
The discussion revolves around calculating the force F between two objects, A and B, which are magnets of equal mass. Object A is subjected to an external force of 3.6x10^-2 N, resulting in an acceleration of 1.6 m/s², while object B accelerates at 2.1 m/s². The user initially calculates the mass of both objects to be 0.0225 kg and derives F as 1.13x10^-2 N. However, a contributor points out that the forces acting on both objects must be considered, noting that since B accelerates faster, the force F must be repulsive. This clarification suggests a reevaluation of the force dynamics to accurately determine F.
BreakPoint
[PLAIN]http://img208.imageshack.us/img208/9987/forcediagram.png
In the figure above, two small objects (magnets for instance) of the same mass exert forces on each other of a magnitude F. When object A is subjected to an external force of 3.6x10^-2 N, A accelerates at 1.6 m/s/s and B accelerates at 2.1 m/s/s as shown. Find F. Neglect other forces, assume accelerations are parallel.
F=ma
ƩF = ƩmƩa
I'm not sure if the solution i got is entirely correct but this is it
ƩF(A) = 3.6x10^-12
ƩF(B) = (3.6x10^-2) + F
I got this because B is accelerating faster which means the force on B must be greater if the masses are equal.
Using this, I found the mass of A, by F = ma
3.6x10^-2 = m(1.6)
m = .0225 kg, so A and B are .0225 kg
To find F, I substitute the mass into F = ma for F(b)
So
(3.6x10^-2)+ F = .0225*2.1
F = 1.13x10^-2 N
Is that correct?
F=ma
ƩF = ƩmƩa
ƩF(A) = 3.6x10^-12
3.6x10^-2 = m(1.6)
So
F = 1.13x10^-2 N
Is that correct?
You have not allowed for F acting on each body. being as B accelerates faster than A - moves away from it - the force F must be repulsive.
For A, 3.6 x 10-2 N acts to the right, anf F acts to the left.
For B, just F acts to the right.
From that you can get what you are after.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
