Newton's Second Law for Rotation
The discussion centers on calculating the angular acceleration and angular speed of a pulley subjected to a time-varying force. At t=3.0 seconds, the angular acceleration is correctly identified as 420 rad/s², but confusion arises regarding the calculation of angular speed. Participants emphasize that since the force—and consequently the torque—is changing, the angular acceleration also varies over time, necessitating the use of integration to find angular speed. The correct approach involves determining angular acceleration as a function of time rather than using a constant value. Ultimately, the key takeaway is the need to integrate angular acceleration over time to accurately compute angular speed.
frig0018
A pulley, with a rotational inertia of 1.0 x 10^-3 kg*m^2 about its axle and a radius of 10 cm, is acted on tangentially at its rim. the force magnitude varies in time as F=0.50t + 0.30t^2, with F in Newtons and t in seconds. The pulley is initially at rest . At t=3.0 s what are its (a) angular acceleration and (b) its angular speed?
(a) \alpha= (r*F(3)) / I = 420 rad/sec^2
(b) unsure, but tried using \omega= \omega_{}0 +\alphat = 1260 rad/s which is wrong and several other variations of that equation.
(see above)
The kinematic equation you used is incorrect because this is only for cases of constant alpha. In this case, since force is changing, torque is changing. And since torque is changing, alpha is changing. Think of the general (geometric?) relationship between alpha and omega.
so is the geometric relationship that when alpha increases, so does omega? do i need to use an integral?
dw= (integral)alpha dt? but how can i differentiate this if there are no variables?
i come up with dw=alpha*t + c but when i plug in t=3, i still get 1260...
Hi frig0018,
alpha is not 420 rad/s^2 except at t=3. To integrate over t you need alpha as a function of (the variable) t.
they are just asking for alpha at t=3 s, which is 420 rad/s^2. I am fairly sure of this because it is the answer in the back of the book... However, i am struggling to figure out omega at t=3 s which should be 500 rad/s but i need the work to back it up and I'm not sure which equations to use.
Your method for obtaining the alpha at t=3 is correct, and your idea of integrating is also correct, it seems you're just stuck on finding the function? Well, look at the way in which you solved for alpha and you'll see you have a general formula for alpha. That should help :)
Yes, your answer for part a looks correct, but my previous comment:
alphysicist said:
Hi frig0018,
was referring to part b. In post #3 you tried to integrate (alpha dt), with the integral running from t=0 to t=3. But if you integrate from t=0 to t=3, you can't just plug in the value of alpha that is true only at t=3. You need alpha as a function of t.
They give you the force as a function of t: F= 0.50t + 0.30t^2. What is alpha as a function of t?
