Newtowns 1st and 2nd laws question.
  • Thread starter Thread starter jovankamcev24
    Laws
In the discussion regarding Newton's first and second laws, participants analyze various force combinations applied to an object to determine conditions for maintaining a constant velocity of 256 m/s. The key point is that an object will move at a constant velocity only when the net force acting on it is zero. Several force combinations are examined, with particular attention given to the third case of 200 N and 201 N, where the forces are unbalanced, resulting in acceleration rather than constant velocity. The conversation encourages participants to show their reasoning and calculations for each scenario. Understanding these principles is essential for applying Newton's laws effectively in physics problems.
jovankamcev24
In an inertial frame of reference, a series of experiments is conducted. In each experiment, two or three forces are applied to an object. The magnitudes of these forces are given. No other forces are acting on the object. In which cases may the object possibly move at a constant velocity of 256m/s?
The forces applied are as follows:
2 N; 2 N
200 N; 200 N
200 N; 201 N
2 N; 2 N; 4 N
2 N; 2 N; 2 N
2 N; 2 N; 3 N
2 N; 2 N; 5 N
200 N; 200 N; 5 N
good question. sounds like homework.
show some work... at least some attempt, however small.
for example, the third case 200;201. What do you think for that one? And why?
