What Caused My Home Phone to Lose Dial Tone?
  • Thread starter Thread starter ifhsu
    Puzzle
The issue of losing a home phone dial tone was traced to a faulty DSL splitter, which was confirmed after troubleshooting the internal wiring and testing connections. Initially, a dial tone was present at the Network Interface Device (NID), indicating that the problem was likely within the house. Despite checking all phone jacks and connections, the dial tone intermittently returned and failed again, leading to a service call to AT&T. The user considered replacing internal wiring and jacks as a cost-effective solution. Ultimately, the problem was resolved by identifying the faulty splitter, which was causing the phone line to short. This situation highlights the importance of checking both internal wiring and external components, such as splitters, when diagnosing phone line issues.
ifhsu
[SOLVED] No dial tone puzzle
I lost home phone dial tone last week. First, I called att service and they said it is an interior wiring problem. I confirmed this by connecting a (good) corded phone in the Network Interface Device. There was a dial tone in NID and I called my home number from my cell.
Then I disconnected all phone jacks inside the house and checked any loose connections. There were all good. I finally called att again asked for service inside my house ($70+ hourly rate) to fix the problem.
The night before the service appointment the phone line suddenly worked for no apparent reason, so I called off the att service. However, the next morning it was dead again and came back alive one time the same day before went dead since 3 days ago.
I have a DSL splitter to a second line and DSL is all functional all this time.
What can go wrong and how to attack this problem? It is a puzzle for me. Need some advice.
Thanks.
Computer science news on Phys.org
could the phone itself be bad?
if that doesnot fix the problem
can you swap the DSL and voice phone lines ? at the out side box
next try
I would replace the wires/ jacks myself and get a new spliter too
as both will cost less then the ''SERVICE VISIT" from att
when I did that at my house I still had a problem
but I then knew it was not inside
the teck found the line to the house from the pole was intermittently shorting
do to hurricane wind dammage
he found that by shaking the line with a meter hooked up
BTW my DSL worked fine even when the phone was dead
DSL with work over only one line/wire voice dial tone needs two good lines/wires
I proved that by hooking up ONE WIRE and going on line
I used the corded phone at NID and it worked. That's how I confirmed it seems to be a interior wiring problem. Only that phone is connected to a jack inside the house right now.
"can you swap the DSL and voice phone lines ? at the out side box next try"
Not sure how to do it, but will look into it.
However, the second line is only available in one room, where DSL & wireless router are located. So, swapping lines won't completely solve the problem. I still need phone connection in the rest of house.
It still could be an outside line problem, right? I wonder how to make att take a closer look.
Thanks.
It was a faulty DSL splitter shorting phone line. Got it fixed. Thanks.
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
I came across a video regarding the use of AI/ML to work through complex datasets to determine complicated protein structures. It is a promising and beneficial use of AI/ML. AlphaFold - The Most Useful Thing AI Has Ever Done https://www.ebi.ac.uk/training/online/courses/alphafold/an-introductory-guide-to-its-strengths-and-limitations/what-is-alphafold/ https://en.wikipedia.org/wiki/AlphaFold https://deepmind.google/about/ Edit/update: The AlphaFold article in Nature John Jumper...
