How Does Nodal Analysis Affect Voltage Distribution in Circuits?
Nodal analysis is crucial for understanding voltage distribution in circuits, particularly at nodes V1 and V3. The current flow to the left and right at these nodes must be considered to accurately calculate voltages. The bottom node is defined as ground, allowing for direct voltage determination at V1 and V3 based on known voltage sources. The discussion highlights a common misconception about combining voltage and current in equations, emphasizing the importance of careful analysis. Proper application of nodal analysis leads to clearer insights into circuit behavior.
vg19
Hi,
I just have a quick question about nodal analysis in the attached file. At v1 and v3, is it not necessary to take into account the current going to the right and left respectivley?
So at v1, -6V + (v1 - v2 / 6k)
and at v3, 24V + (v2 - v3/4k)
Thanks a lot!
For this case since the bottom node is defined to be ground, and you know the voltage difference for the voltage sources so V1 and V3 are known by inspection. Besides look at what your trying to do. You have at V1:
-6V + (V1-V2)/6K, your trying to add voltage to current. That doesn't make sense.
ahhh I got to pay more attention...Thanks!
