How to Apply a Non-Uniform Sinusoidal Load on a Cylinder in ANSYS?
To apply a non-uniform sinusoidal load on a cylinder in ANSYS, users can utilize APDL (ANSYS Parametric Design Language) to define the load based on node or element coordinates. APDL allows for batch scripting, enabling the definition of custom load functions such as sin(x). Detailed documentation is available to assist in understanding the implementation process. Users can also request sample APDL files for practical guidance. The discussion emphasizes the need for applying consistent loads across coordinates on the cylinder.
elena
How can I set a non uniform load (for example sin(x)) in on a cylinder ring?
Apdl
Hello elena,
you may get the coordinate of the node/element by apdl and define any function for the load also using apdl. Apdl is some kind of batch/script programming implemented within Ansys. You might inspect the detailled documentation/help for more informations. You also can send me a pm for a sample apdl-file.
Thanks so much and sorry that i was late to thank you!
I'm also studing same problem. I have a cylinder. I want to apply a non uniform load. I can apply one coordınate. I want to apply same load as parallel . Can you help me? How can I set load (depends on only x coordinate) in on a cylinder
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
