Archived Nonlinear Dynamics and Chaos, Strogatz: 2.1.5
A mechanical system governed by the equation \(\dot{x} = \sin(x)\) can be modeled by a pendulum, particularly an inverted pendulum in a viscous medium. The discussion highlights that \(x^* = 0\) is an unstable fixed point because small deviations lead to increasing oscillations, while \(x^* = \pi\) is stable as small deviations result in restoring forces that bring the system back to equilibrium. Visualizing the dynamics through diagrams can clarify stability and instability by showing the direction of motion around these points. Participants suggest using energy conservation principles and evolving equations to further understand the system's behavior. Overall, the conversation emphasizes the importance of physical intuition in analyzing nonlinear dynamics.
Niteo
a) Find a mechanical system that is approximately governed by \dot{x}=sin(x)
b) Using your physical intuition, explain why it now becomes obvious that x*=0 is an unstable fixed point and x*=\pi is stable.
\dot{x}=sin(x) (?)
I'm thinking a pendulum can be used as a mechanical system that varies with sinθ, but I'm not sure how to solidify my answer.
Could it possibly be an inverted pendulum in a very viscous medium?
Consider a particle sliding over terrain y=f(x). Assuming conservation of energy (and some convenient total) what is the PE at x? What does that yield for f?
Question of understanding what they want. I think all you need to do is draw a diagram of the given function (familiar!) extending a little further on both sides than the points mentioned; xdot is the ordinate, but more important, with little horizontal arrows show which way x Is moving on each side of the named points, and you will soon see what they mean about stability/instability. Just explain this in your own words.
Immerse your pendulum in honey and evolve your equations. When you finish, you're going to get a second order differencial equation. At this point, you got to be audacious and destroy the second order term. Voilà.
The OP never came back, and this is years old.
But for what it's worth, I believe my suggestion in post #2 gives a very easy model, no approximations needed.
