Nonlinear second order ODE describing a force field
The discussion revolves around solving a nonlinear second-order ordinary differential equation (ODE) derived from a potential energy curve in physics. The force is defined as F(x) = -dU/dx, leading to the equation x²(d²x/dt²) = - (a/m)b + (ba/m). The poster struggles with solving this ODE and has attempted various substitutions and integration techniques without success. A suggestion is made to apply the chain rule, using the relationship d²x/dt² = v dv/dx, where v = dx/dt, to simplify the problem. The thread highlights the challenges of solving nonlinear ODEs and seeks further assistance from knowledgeable individuals.
thetasaurus
Not sure if this topic belongs here, but here goes.
From the AP physics C 1995 test there is a problem that gives the potential energy curve U(x). With F=-\frac{dU}{dx} in one variable,
F(x)=-\frac{a}{b}+\frac{ba}{x^{2}}
Where a and b are constants. Now I need to get x(t)
Dividing by mass and multiplying by x^2:
x^2\frac{d^2x}{dt^2}=-\frac{ax^2}{mb}+\frac{ba}{m}
Unfortunately I do not have the skills to solve this differential equation.
x=y, \frac{-a}{mb}=b, \frac{ba}{m}=k, y'=u
y^2y''=by^2+k
I tried to eliminate the y'':
y'dt=udt
\int{y'dt}=\int{udt}
y=ut+CAnd that doesn't really get me anywhere. Anyone with knowledge of nonlinear ODEs care to help? I tried Wolfram, but even with my Pro free trial it took to much computing time and never gave me a solution.
Also since this wasn't required of the problem per se, and I just want to solve this, I'm not sure what forum it should be in.
Thanks.
hi thetasaurus! :smile:
try the standard trick (from the chain rule) …
d2x/dt2 = v dv/dx (where v = dx/dt)
(btw, that's where 1/2 mv2 comes from :wink:)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
