Noob to mechanical engineering - how do I find the part I need
The discussion revolves around finding specific mechanical parts, particularly hinges, for a project. Participants share their experiences and suggestions regarding terminology, sourcing, and design considerations within the context of mechanical engineering.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested, Homework-related
  • One participant expresses difficulty in finding mechanical parts due to a lack of vocabulary in mechanical engineering.
  • Another suggests using a catalog to learn terminology and mentions that less common items tend to be more expensive, recommending the use of common hinges if cost is a concern.
  • A participant proposes that many parts can be fabricated by oneself if one has welding skills and the ability to accurately bend metal.
  • One participant identifies the hinge in question as resembling a rudder hinge used on small sailboats and suggests a design similar to a toilet roll holder.
  • Another participant recommends a specific website, McMaster-Carr, as a resource for a wide variety of mechanical parts, noting its intuitive organization.
Participants generally agree on the importance of understanding terminology and sourcing common parts, but there are varying opinions on the best approach to finding or creating the needed hinge.
Participants mention specific resources and design considerations, but there are no settled definitions or consensus on the exact type of hinge needed.
Individuals new to mechanical engineering, hobbyists looking for mechanical parts, and those interested in DIY fabrication techniques.
chewmanfoo
I build things. I need mechanical parts from time to time, and I always have trouble finding the parts I need because I don't have a vocabulary from the mechanical engineering world - I hope to acquire the language by living in the forum for a while (and thinks in advance to anyone who can help).
This week I am looking for a hinge. The purpose of the hinge is to allow a stiff piece to flex without breaking. I drew a picture of the hinge in sketchup:
http://i.imgur.com/WRTq4uv.png
Googling around, I found this piece: http://www.hardwaresource.com/hinges/SPECIALTY+HINGES/Heavy+Duty+Hinges/Heavy+Duty+Gate+Hinges/4%22+Bolt-On+Pivot+Hinge
which seems to fit the bill. But it's too costly because it supports weight limits I don't need (I only need about 50 lbs. per hinge)
Can anyone suggest what this kind of hinge is called? I need to buy one for a relatively cheap price - does anyone have a good source for mechanical pieces I can buy off the internet?
You can learn a lot of the terminology via a good catalog; something like http://www.grainger.com/category/hardware/ecatalog/N-bib As for prices, the less common the item, the more expensive. So you may want to revisit your design and use "common hinges" or a different technique if cost is the main issue.
You can also make a surprisingly large amount of things yourself if you know how to weld and if you are able to bend metal plates and pipes accurately.
wow that's genius! Thanks a lot guys. I came to the right place.
Also take a look at www.Mcmaster.com they have a ton of parts for all sorts of things and its organized really intuitively in an easy-to-navigate way.
