Normal and Friction Force Relationships went turning curbs
To determine if the frictional force is sufficient for a car to maintain circular motion while turning a curb, one must analyze the relationship between the coefficient of friction, normal force, and the required centripetal force. Given a car mass of 1350 kg, a speed of 15.3 m/s, and a turning radius of 40 m, the calculated acceleration is 0.173 m/s². The required centripetal force to keep the car in circular motion is derived from this acceleration, and the frictional force must equal or exceed this value. With a coefficient of friction of 0.500, the frictional force calculated is 6620 Newtons, which must be compared to the required force to determine if the car can safely navigate the turn. The discussion emphasizes the need to understand the underlying equations rather than just the numerical values.
daniel.j
how can you tell if the frictional force is great enough to keep a car turning a curb in circular motion based on the coefficient of friction and the normal force?
If a vehicle of mass m turns a corner radius r at speed v, what is its acceleration? What force is needed to provide that acceleration? Where will that force come from?
Acceleration: 0.173 m/s/s
Force is coming from engine but the street is wet with oil.
A car with a velocity of 15.3 m/s follows a circular road that has a radius of 40 m. The car has a mass 1350 kg. The pavement is wet and oily so the coefficient o friction between the tires and the road is only .500. The frictionall force that I calculated came out to be 6620 Newtons. Is this frictional force large enough to maintain the car in circular motion?
Please don't just tell me numbers. To figure out what you're doing I then I have reverse engineer the calculations. Let's just work with the algebra until we agree the equations.
A car mass M turns a corner radius R at constant speed V. What is its acceleration (magnitude and direction)? What force will provide that acceleration (and no, it's not the engine)? How large is the force? What limit on the size of the force might mean it is not large enough to turn the corner?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
