Normal Distribution: B,C,D Likely?
In summary: I'm not sure if they were. B is false, all mammals have the same number of cervical vertebrae. In summary, the student is trying to find out what distributions are likely to be seen when looking at a list of biological data. The student is having trouble deciding between A),B),C) and D). The student is having trouble understanding the answer to the question.
leena19
186
Which of the following is/are likely to show normal distribution?
A) Numbers of cervical vertebrae in different species of mammals
B) Age distribution of children in school
C) Number of fruits in mango trees in an orchard
D) Fasting blood glucose levels of healthy people
E) Diameters of pencils manufactured in a factory
A normal distribution graph is bell-shaped,so A) can't be true ,cause all mammals have the same number of cervical vertebrae and I guess E)would also not show a normal distribution cause the pencils manufactured would mostly be of the same diameter.
I'm having trouble deciding between B),C) and D).
would really appreciate a quick response.
Thank you.
Sure the pencil diameters won't be exactly the same; measured carefully, the values will differ but will cluster around an average with some distribution, presumably the normal distribution.
Will the childrens' ages cluster around a single point, with the frequency trailing off for ages on either side?
Thank you very much for replying!
No.
So far E) would show normal distribution.
And I'm guessing D) would also show normal distribution cause the fasting blood glucose level would be in the range of 80-120mg/100ml,so the frequency may cluster around a point and trail off on either side (of 80 and 120,maybe?)
Still having trouble with C) Number of fruits in mango trees in an orchard.
If the statement were number of trees in an orchard,I guess it won't be a normal distribution,but the number of fruits on the trees?
One problem is that this is a vague question. I don't believe any physical value can belong to a truly normal distribution, as such a distribution allows for the possibility of arbitrary large positive and negative numbers. We can only say that the real-life distribution is approximately normal. So while a pencil diameter cannot be negative, the variance of actual pencil diameters is so small that if we fit a normal distribution to a sample, the predicted frequency of negative-diameter pencils would be effectively zero (say, 10-50, for example). But what if part of the manufacturing process is discarding pencils that lie more than one standard deviation away from the mean? Obviously this would produce a non-normal (specifically, a truncated normal) distribution. So we have to make some assumptions and try to guess what the question-writer was looking for.
Here's another question: does the question-writer mean for us to rule out populations with integer values (like fruit counts)? After all, the normal distribution is a continuous distribution. I don't know; it has to do with whether you're learning the material at a high school / college / grad school level and how the normal distribution was defined to you.
Urm...I'm having a hard time trying to understand any of the above. :(
This question is from a local A-Level biology paper.
and all I know is that most of the biological variables conform to a normal distribution and that in a normally distributed population,about 68% fall within 1 Standard Deviation,98% within 2 SD and 100% between 3 Standard Deviations.
Also the answer to this question is 5) which means
if the ans was,
1- A,B,D would be correct
2 -A,C,D
3-A,B
4-C,D
5-Any other response or combination of responses correct,
but knowing this doesn't help much:(
So you mean the answer says all 5 choices are correct? If so, I'm inclined to say that this question (and its answer) is totally rubbish.
A normal distribution will have a mean where it peaks, sort of an "expected value"
D and E are plausibly normal.
C...maybe, if they were asking for number of fruits in each tree, and if all the mango trees are the same.
I'm pretty sure A is not governed by this sort of distribution, and for B you would expect a uniform distribution within that age group, no?
I think that's what they mean.
No, there are seasonal fluctuations. For example people have more time for sex during vacations, and vacations are in Summer, so there is a peak around April/May (at least on some parts of the northern hemisphere).
:bugeye::bugeye::bugeye: okay...
There is more to it - there are peaks like that 9 months after major power outages :wink:
Sorry,for not being very clear.By answer (5) it could be any combination of responses other than those given in 1,2,3 and 4.In the sense,it could be either A,B,C,D or B,C or A,C or E or A,E & so on...
Anyway I figured out,that C) shows normal distribution and that number of fruits,number of flowers,size of fruits and seeds all come under polygenic inheritance,thus ,they all show normal distribution.It was right there in my notes.I was just looking at the wrong set(the statistics part not the note on genetics)so I guess the answers are C,D and E..
1. What is a normal distribution?
A normal distribution is a type of probability distribution where most of the values are clustered around the mean, with fewer values at the extremes. It is often referred to as the "bell curve" due to its characteristic shape.
2. How is a normal distribution graphically represented?
A normal distribution is graphically represented by a symmetrical bell-shaped curve, with the mean at the center and the standard deviation determining the spread of the curve.
3. What does it mean for data to be normally distributed?
When data is normally distributed, it means that the majority of values fall close to the mean, with fewer values further away from the mean. In other words, the data is evenly spread out on both sides of the mean.
4. How can I determine if my data follows a normal distribution?
There are several ways to determine if your data follows a normal distribution, such as visually examining a histogram or using statistical tests like the Kolmogorov-Smirnov test or the Shapiro-Wilk test. Additionally, you can calculate the skewness and kurtosis of your data and compare it to the expected values for a normal distribution.
5. Why is the normal distribution important in statistics?
The normal distribution is important in statistics because it is a common distribution that occurs in many natural phenomena. It is also used as a basis for many statistical tests and models, such as the t-test and linear regression. Additionally, many statistical methods and assumptions are based on the assumption of normality.
  • General Math
  • Quantum Physics
