Now it is a simple matter to find the current in each of the resistors.
  • Thread starter Thread starter hobo skinoski
The discussion focuses on analyzing a circuit with four resistors connected to a battery, where the goal is to determine the potential difference and current across each resistor in terms of the battery's emf (E) and total current (I). The resistors have values R1 = R, R2 = 2R, R3 = 4R, and R4 = 3R. Participants suggest calculating the equivalent resistance of the circuit to find the current from the battery, which involves combining resistors in series and parallel. The method includes finding the equivalent resistance for R2 and R3, then combining that with R4, and finally adding R1 to determine the total resistance. The analysis concludes with the current distribution across the resistors based on the calculated equivalent resistance.
hobo skinoski
Four resistors are connected to a battery as shown in the figure. The current in the battery is I, the battery emf is E, and the resistor values are R1 = R, R2 = 2R, R3 = 4R, and R4 = 3R.
-Determine the potential difference across each resistor in terms of E.
-Determine the current in each resistor in terms of I.
-In the limit that R3 → infinity, what are the new values of the current in each resistor in terms of I, the original current in the battery?
V=IR
Rtotal=R1+R2+... (Series)
1/2Rtotal=1/R1 + 1/R2 ... (Parallel)
I've tried a bunch of different combos, and I'm just wondering if there is some sort of way to do this.
hmm still trying. anyone out there?
R2 and R3 are in series...we'll call their combination Rs. R4 is parallel to Rs...we'll call their combination Rp. R1 is in series with Rp...we'll call their combination Rt. Once you find Rt, the circuit should simply be a battery in series with a resistance of Rt. From this, you could find I1, the current running through the battery and R1. I1 splits into I2 and I3 at a junction. Note that the voltage between the junctions is the same per path.
hobo skinoski said:
Four resistors are connected to a battery as shown in the figure. The current in the battery is I, the battery emf is E, and the resistor values are R1 = R, R2 = 2R, R3 = 4R, and R4 = 3R.-Determine the potential difference across each resistor in terms of E.
V=IR
As Gear300 suggests you should first find the equivalent resistance of the entire network because that will yield the current from the E source. Then it is simply a matter of splitting the current between the legs as you go through the network.
The equivalent resistance R1234 is found by finding
R23 = R2 + R3
Then
R234 = R4 || R23
Then
R1234 = R1 + R234
Then I = E/R1234
