Null geodesics of a Kerr black hole
Dick Taid
Hi,
From the Kerr metric, in geometrized units,
\left(1 - \frac{2M}{r}\right) \left(\frac{dt}{d\lambda}\right)^2<br /> + \frac{4Ma}{r} \frac{dt}{d\lambda}\frac{d\phi}{d\lambda}<br /> - \frac{r^2}{\Delta} \left(\frac{dr}{d\lambda}\right)^2<br /> - R_a^2 \left(\frac{d\phi}{d\lambda}\right)^2 = 0
where R_a^2 = r^2 + a^2 + \frac{2Ma^2}{r} is the reduced circumference, a \equiv \frac{J}{M} is the spin parameter and \lambda is some affine parameter. I need to calculate the equations of motion.
I want to solve the Lagrange equations
-\frac{d}{d\sigma}\left(\frac{\partial L}{\partial\left(dx^\alpha/d\sigma\right)}\right)<br /> + \frac{\partial L}{\partial x^\alpha} = 0
for the Lagrangian
\mathcal{L}\left(\frac{dx^{ \alpha}}{d\sigma},x^{\alpha}\right) <br /> = \left(-g_{\alpha\beta}\frac{dx^{\alpha}}{d\sigma}\frac{dx^{\beta}}{d\sigma}\right)^{1/2}
The problem is, that the metric is null so the Lagrangian is as well (?). Is it possible to calculate the equations of motion using this approach, or am I "forced" to do it the hard way, using
\frac{d^2x^{\alpha}}{d\lambda^2} <br /> = -\Gamma_{\beta\gamma}^{\alpha}\frac{dx^{\beta}}{d \lambda}\frac{dx^{\gamma}}{d\lambda}
finding the Christoffel symbols, and so forth?
Yes - you can use the Lagrangian approach.
Use the version of the Lagrangian without the square root - you already have it in your first equation.
Unless you really like differentiating square roots :smile:
Hmm, thanks. :)
I'm not entirely convinced though. But that's probably more due to my inability to state what it is I want with it. Here's everything (well, most of it):
I'm doing a little project right now, where I'm trying to plot the timelike and lightlike orbits of some test particle. I've done the timelike part by using the Lagrangian
\mathcal{L}(r,\dot{r},\phi,\dot{\phi}) = \frac{d\tau}{dt} = \left[\left(1 - \frac{2M}{r}\right)<br /> + \frac{4Ma}{r} \dot{\phi}<br /> - \frac{r^2}{\Delta} \dot{r}^2<br /> - R_a^2 \dot{\phi}^2\right]^{1/2}
Solving Lagrange's equations for this gives the equations of motion (as functions of the observer time t)
\begin{align*}\ddot{r} &amp;= -\frac{1}{r^4\Delta}\left[r^2\dot{r}^2\left(a^2(r - 2M) - 3Mr^2 + 2Ma\left(a^2 + <br /> 3r^2\right)\dot{\phi}\right)\right. \nonumber\\<br /> &amp;\qquad\qquad \left. + \Delta^2\left(M - 2Ma\dot{\phi} + \left(Ma^2 - r^3\right)\dot{\phi}^2\right)\right],<br /> \label{eq:EqMr}\\<br /> \ddot{\phi} &amp;= -\frac{2\dot{r}}{r^2\Delta}\left[\left(Ma + a^2(r - 2M)\right)\dot{\phi}<br /> + Ma\left(a^2 + 3r^2\right)\dot{\phi}^2\right].\end{align*}
Those can easily be transformed into first order differential equations by setting v = \dot{r} and \omega = \dot{\phi} and using
\frac{dt}{d\tau} = \frac{1}{\Delta} \left[R_a^2e - \frac{2Ma}{r}\ell\right],
\frac{d\phi}{d\tau} = \frac{1}{\Delta} \left[\frac{2Ma}{r}e + \left(1 - \frac{2M}{r}\right)\ell\right]
and
\mathcal{E} \equiv \frac{e^2 - 1}{2} = \frac{1}{2}\left(\frac{dr}{d\tau}\right)^2 + V_\text{eff}(r,e,\ell),
where
V_\text{eff}(r,e,\ell) = -\frac{M}{r} + \frac{\ell^2 - a^2(e^2 - 1)}{2r^2} - \frac{M(\ell - ae)^2}{r^3}
to calculate the initial conditions of the first order equations (i.e. v_0 = \frac{dr/d\tau}{dt/d\tau} = \frac{dr}{dt} and so on), and then using MATLAB to compute the orbits. I want to do the same with photon orbits. That is, compute Lagrange's equations for a Lagrangian for the lightlike orbits, as functions of time.
Another thing, I've seen many removing the square root in the Lagrangian. Why is that allowed? Not that it matter to my calculations, as those are done with Mathematica anyways -- I'm just wondering.
I think the easy answer is to vary the action, turn the crank as usual, and discover that the Lagrangian without the square root does indeed yield the geodesic equation as its equations of motion.
If I remember correctly, you can also use some integral inequality (Cauchy maybe?) to show that if the action integral with the square root is extremized, then so too is the action integral without the square root. Perhaps someone wiser than me can clarify...
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
