• Support PF! Buy your school textbooks, materials and every day products Here!
Numerical PDE's
  • Thread starter Nusc
tiny-tim
25,832
249
plug P_n = ((-c)^n).sin((n+1)∆)/sin∆ (and similarly for P_n-1 and P_n-2) into P_n = -2c.cos∆P_n-1 - c^2 P_n-2.
DOne. Doing that gives me:
sin((n+1)∆) + sin((n-1)∆) = 2.cos∆.sin(n∆),
And i got this after substituting Pn and Pn-1 and Pn-2. not through standard trig. Is this correct? So once I've shown this what does this mean? how does this verify that these are the e-values? Then I have to show that the e-vectors are as stated in the first post
tiny-tim
25,832
249
Yes, you got it from substitution. Then you still have to use standard trig to check that that equation is right!
If you put any old P_n in, you'd still get some trig equation … but it would be rubbish! Only a valid P_n will give a valid trig equation!
I've been assuming that you've done, in class, solution of eigengvalues λ of a matrix M by "characteristic equation" … that is by the equation M - λ.I = 0.
Have you?
yeah
So recap, I found a general characteristic equation for this nxn symmetric -tridiagonal matrix.
we assumed that lamdba = b+2c.cos(theta) is an e-value but I need to prove this and I dont see how what we did proved this at all.
we stuck lambda back in P_n and it gave us a solution to the general characteristic equation i dont know what this represents.
One could have just avoided this method completely and solved
AX=Lambda*B but since I'm this far I might as well finish it off
Eventually we have
sin((n+1)∆) + sin((n-1)∆) = 2.cos∆.sin(n∆) now I need to verify this with standard trig. How do I do this?
Then I stil have to find the e-vectors.
Was there not a more concise way of doing this problem?
  • #31
753
Actually I finished the problem using a different method and it's alot more elegant that the crap i just went through.
Thanks for the help tim.
you can close this thread
  • #32
753
Hi Nusc! :smile:
Hint: if the characteristic equation of the n x n matrix is Pn = 0, find a recurrence relation expressing the polynomial Pn in terms of Pn-1 and Pn-2.
Then either solve that recurrence relation by normal methods, or (since the question gives us the solution) define ∆ by: lambda = b + 2c.cos∆.
You should find that Pn = cos(n∆).
And then … ? :smile:
What did you mean by normal methods?
  • #33
tiny-tim
25,832
249
Hi Nusc! :smile:
Goodness, that was a long time ago!
I meant that if a sequence {An} has the recurrence relation
C0An + C1An+1 + … + CkAn+k = 0,
then you pretend that it's a polynomial
C0 + C1x + … + Ckx^k = 0,
factor it into (x - P)(x - Q)…(x - Z),
and then the solutions are linear combinations of {An = P^n} and {An = Q^n} … and {An = Z^n},
except that for repeated roots (x - P)^2, there's an extra {An = n*P^n},
(x - P)^3, there's an extra {An = n^2*P^n}, and so on. :smile:
(In other words, recurrence relations are a lot like polynomial differential equations.)
  • #34
753
Let's say we had an nxn matrix: ( I didn't draw the l dots but assume its nxn)
[tex]
\left[\begin{array}{cccc}0 & -c & 0 & 0 \\ -c & 0 & -c & 0 \\ 0 & -c & 0 & 0\end{array}\right]
[/tex]
We know previously that
[tex]
P_n = -\lambda P_{n-1} - c^2 P_{n-2}
[/tex]
How do I solve for lambda?
  • #35
tiny-tim
25,832
249
[tex]P_n = -\lambda P_{n-1} - c^2 P_{n-2}[/tex]
Hi Nusc! :smile:
We rewrite it [tex]P_n\,+\,\lambda P_{n-1}\\,+\,c^2 P_{n-2}\,=\,0[/tex]
so we see the roots are (-λ ±√(λ² - 4c²))/2;
we defined ∆ by λ = 2c cos∆, so we can rewrite this as:
-c cos∆ ± ic sin ∆, = -c e^{±i∆}.
So the solutions are Pn = A(-c^n)e^{in∆} + B (-c^n)e^{-in∆},
or A(-c^n)cos(n∆) + B (-c^n)sin(n∆). :smile:
  • #36
753
Well in this case we're not given [tex]\lambda [/tex] so what now?
  • #37
tiny-tim
25,832
249
Well, remember that the whole point was that the characteristic equation is Pn = 0.
So we just choose A and B and ∆ so that Pn = 0, and so that the the values for P1 and P2 (which are esy to find directly) are correct. :smile:
  • #38
753
Hi Nusc! :smile:
ARe you suggesting here that [tex]P_n= P_{n-1}= P_{n-2}[/tex] ? Why is that true?
We don't know ∆
  • #39
tiny-tim
25,832
249
No … P_N is the characteristic determinant of the matrix in the question.
[tex]P_n= P_{n-1}= P_{n-2}[/tex] is an equation which we use for calculating P_N. We do so because P_N is far too complicated to calculate directly.
So we build it up, using that equation, until we get to n = N.
Once we have P_N, we put P_N = 0 … because that's what the characteristic determinant is for!
But we don't put any other P_n = 0 … if we did, it would give the wrong result.
To put it another way … we have been looking for what we have been calling λ.
It would probably have made you happier if we'd called it λN.
Solving PN = 0 gives us values for λN.
Solving Pn = 0 for any other value of n gives us values for λn, not λN. :smile:
We don't know ∆
We find ∆ (or ∆N, if you prefer) from PN = 0.
Then we find λ from ∆. :smile:
(It is easier to find ∆ first, then λ.)
  • #40
753
Sorry, what does ∆ supposed to represent in this case?
  • #41
tiny-tim
25,832
249
  • #42
753
But we don't know λ !
λ does not equal 2c cos∆
  • #43
tiny-tim
25,832
249
Well of course we don't know λ …
λ is what the question asks us to find, isn't it? :confused:
Yes it does …
We defined the substitution b - λ = -2.c.cos∆, to make the equations easier, and you've chosen b = 0 (in your post #34), so λ = 2c cos∆. :smile:
Related Threads for: Numerical PDE's
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
