Solve Numerical Problem: Proton Mass, Charge, Speed & Electric Field Strength
  • Thread starter Thread starter Samia qureshi
    Numerical
To determine the strength of the electric field affecting a proton, the work-energy theorem is suggested as a suitable approach. The proton, with a mass of 1.67*10^-27 kg and a charge of 1.6*10^-19 C, experiences a speed reduction of 50% after traveling 1.0 cm in the field. Newton's Second Law of Motion is also mentioned as a potential method for solving the problem. Some participants express a preference for the work-energy theorem over Coulomb's law for simplicity. The discussion emphasizes the importance of selecting the right formula to analyze the proton's motion in the electric field.
Samia qureshi
A Proton Of Mass 1.67*10^-27kg And Charge 1.6*10^-19c Moving At An Initial Speed 3*10^6m/s Against A Uniform Electric Field Has Its Speed Reduced By 50% After Covering A Distance Of 1.0cm In The Field. Determine The Strength Of The Field? help me solve this problem what formula should i use to solve it.
Likes lord sauron
Likes Samia qureshi
The work-energy theorem can be used also to solve this.
can't we use F=K[q1][q2]/r^2 ?
I think it's easier to use work-energy theorem
Likes Samia qureshi
i will try this also Thank you :)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
