Numerics FEA interpolation order vs element number
Interpolation order in finite element analysis (FEA) affects the accuracy of results, with higher orders like quadratic providing better precision than linear. The choice between using fewer high-order elements versus more low-order elements depends on the specific application and the stress gradients present in the model. Fewer high-order elements can lead to reduced solving time and smaller model sizes, yet may require careful consideration of element count for accurate results. Ultimately, the decision should align with the analysis goals and the complexity of the stress distribution. Understanding these trade-offs is crucial for effective FEA modeling.
member 428835
Hi PF!
Can someone help me understand the difference between interpolation order (linear, quadratic, etc) vs element number?
Like, if we had a 1D beam (for simplicity) what's the difference between using 1 element and a quadratic interpolation vs 2 elements but a linear interpolation?
Not sure if this is posted in the right spot?
In the end the choice between more low-order elements or fewer high-order elements will depend on your application, and the stress gradients in the area you're analyzing. Fewer high-order elements can be more efficient in terms of solving time and model size, but it may still be necessary to have a large number of them depending on your goals.
Here is some additional reading on the topic: http://www.padtinc.com/blog/the-focus/mid-side-nodes-do-they-really-help
Thanks!
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
